Old 05-May-2005, 14:44   #1
Brogins Brogins is offline
Brogins's Avatar
Mood: PENSO POSITIVO....SEMPRE!!
Silly question on 999 front light..
..which is always turn on..
Is tape OK for track days or is going to melt with consequential mess on the nose fairing??
It is better to disconnect the electric connection??
fabio
Old 05-May-2005, 14:47   #2
It's recessed into the fairing, so can you not just tape over the hole? which would be cooled by the airflow
Old 05-May-2005, 14:57   #3
Mood: Diet
You can pull one of the fuses, much easier than remove the connector
Old 05-May-2005, 16:37   #4
HW HW is offline
The (one and only) track day I have been on with No Limits there were UJM's with all their lights on and uncovered. How strict are other companies?
It was quite disconcerting being behind on of them and his brake light came on ... almost expected him to indicate!
Old 05-May-2005, 18:36   #5
Yep,thats the way to go.
If you just tape over the lens it could get hot and melt.
I forgot to mention,its the 15A fuse in the fusebox.
[Edited on 5-5-2005 by KeefyB]
Old 05-May-2005, 22:38   #6
Brogins's Avatar
Thanks guys.. yes.. the fuses!!
The message board is a great thing...
Keefy.. and for the rear brake? ..I know I shouldn'use it but..
[Edited on 5-5-2005 by Brogins]
Old 06-May-2005, 07:04   #7
For track days its easy to remove the whole rear light assembly.All you need is a 4mm allen key to remove the three bolts.(One above the rear light and two underneath.)
Once the light unit has been released you can simply just unplug the wiring.Its also a good idea to wrap a bit of insulation tape around the connector to stop anything getting in there,especially if its wet!
Takes about five minutes to do.
Old 06-May-2005, 23:30   #8
RedMist RedMist is offline
Bikes: Monster S4R & 749S
RedMist's Avatar
Mood: Mellow Yellow
On my last couple of track days last year, I was told that new guidelines are that taping over lights is not a requirement - as you can see by the avatar!
