Old 05-May-2005, 21:17   #1
ttstu ttstu is offline
Mood: On the mend!
Corse Stripe Fitment.
Just bought one off eBay didn't realise I could buy one from someone on here.
Any tips on fitting would be appreciated.
Below should be a picture of one from another post.
How do I get it to go over the radiused front edge?
Cut it to shape of fold it under?
As I say any advice would be appreciated but be quick as I may not resist the temptation to get stuck in and mess it up!
http://image.inkfrog.com/pix/hyperdrive/ebay_corse.jpg
Old 05-May-2005, 21:21   #2
yeti yeti is offline
yeti's Avatar
For starters, don't even think about fitting it "dry" if you have never done this before. Peel the backing paper off first, then believe it or not drop the sticker into a bucket of warm water with no more than a couple of drops of fairy liquid or the like. When you lift it out you will be able to apply it easily and even shift it about if not in exactly the right place. Then use a palstic squegee to squidge the remainin liquid out.
With regard to the front, you may just have to trim it off carefully with a craft knife.
Old 05-May-2005, 21:24   #3
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Actually John you're better off fitting it dry. You need to stretch the center so that it will follow the curve of the fender..
Old 05-May-2005, 21:27   #4
keefer keefer is offline
keefer's Avatar
don't you just love this board ?
what you gona do now then ttstu ?
go wet IMO
maybe we could start a poll
Old 05-May-2005, 21:28   #5
Mood: On the mend!
Oh no!
Wet or dry?
Fender on or off?
Trim before or after fitting?
Old 05-May-2005, 21:29   #6
Carbon749's Avatar
Mood: I own a flame thrower
Float the main part on with a very thin film of soapy water. At the front edge heat it slightly with a hair dryer .... I DO MEAN SLIGHTLY .... and let it stretch to shape.
Old 05-May-2005, 21:33   #7
khu996 khu996 is offline
khu996's Avatar
Hey, you could have it sprayed on? Or perhaps powder coated?
Old 05-May-2005, 21:35   #8
Mood: On the mend!
Thanks Khu996. If I mess it up I may consider it.
Old 05-May-2005, 21:39   #9
Why don't you send a u2u to revdecal? He runshis own decal business, he may know what he's talking about.
Old 05-May-2005, 21:43   #10
tricky tricky is offline
Mood: Need spares
Great advice from everyone, so not much I can add apart from be in a good mood when you start applying the stripe
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:09.
