Old 15-May-2003, 19:38   #1
yeti yeti is offline
yeti's Avatar
Cast iron brake rotor problem
Got a pair of Brembo cast iron front brake discs on the 996 couple with Brembo monoblock calipers (996R 4 pad). At the start of the season I fitted a set of Bendix pads as recommended and supplied by JHP. Since then my discs have scored badly on all four sides and are deeply grooved now.
Before changing the rotors, and perhaps having the problem re-occur, can anybody shed any light on why this has happened?
Bearing in mind I want to keep the monoblock calipers, would anybody recommend fitting a PFM rotor replacment kit, or sticking with Brembo?
Finally, where's the best place to buy these things bearing in mind I'll do the work myself?
Old 15-May-2003, 19:44   #2
adam adam is offline
Mood: happy
Yeti
i have just bought a pair of PFM iron floaters and was also recommended Bendix pads, hope i dont see the same results as you. Told to steer clear of sinterd pads for obvious reasons.
Old 15-May-2003, 19:57   #3
yeti's Avatar
Sorry, what are the "obvious" reasons vis a vis sintered pads?
Old 15-May-2003, 20:56   #4
Mood: happy
the sinterd pads will grind into the iron rotors and put fantastic grooves in them.
pads with no metal in them , thats what i was told.
Old 15-May-2003, 21:24   #5
Mood: aving a laff
Not 100% sure if yours are the same but my Bendix pads are MF Sintered, probably have metal in them??
Dont know for sure but I have no scoring on standard discs from a 996?
Old 15-May-2003, 22:46   #6
Desmoboy Desmoboy is offline
Bendix pads are sintered. Sintered aren`t good for Cast Iron(as you are finding out), apart from wearing them down faster, they also are prone to rust/bind onto the disc when they get wet. So unless you don`t plan on cleaning the bike after each ride...
I`ve heard the best ones to use are Ferrodo Platinum pads
[Edited on 15-5-2003 by Desmoboy]
Old 15-May-2003, 23:23   #7
Mood: aving a laff
Me thinks now Bendix do a non-sintered version but best contact Mike Davies as he is a supplier of Bendix so should know?
Would be good to know how you get on with them?
Old 15-May-2003, 23:40   #8
yeti's Avatar
Don't think there is ANY doubt. I have sintered pads, hence the scoring/grooving! F**K. Looks like I best be getting myself a new pair of discs and some non-sintered pads.
Can't blame John Hackett though cos the bike is a 2001 bike and he probably thought it had stainless rotors. Didn't expect a knob head like me to have already changed them for cast!!!!
PFM or AP? Whats the concensus?
Old 16-May-2003, 00:34   #9
Felix Felix is offline
Brembo! Unless you like to gamble with warped rotors! Yes, Bendix do a non-sintered pad as do many others.
Old 16-May-2003, 10:50   #10
yeti's Avatar
Have been told it's almost impossible to pick up Brembo cast iron discs now as Brembo have gone over to all stainless.
Think PFM is looking most likely.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:50.
