Old 07-May-2005, 21:03   #1
Rotty Rotty is offline
Two bits for my 600ss
Hi,
Possibly a long shot, but before ordering these bits I thought I'd see if anyone here has them spare and for sale. I'm not sure the correct technical term for either bit, but here's my best description:
* A gold fairing cup, which is the washer that goes between the fairing and the bolt that holds it in place.
* The red bit of plastic that goes behind the fork on the right side. I guess the purpose is to tidy up the bolt holes that are left because the 600ss only has a single front disc.
Cheers,
Rotty
Old 07-May-2005, 23:16   #2
I think I might have a spare gold thingy. I'll check next time I'm in the garage.
As for the plastic - it's a good reason to upgrade to twin disks
I can flog you a single disk cheap if you want one as I upgraded mine to twin and ended up buying a pair of disks for £60. The 916 master cylinder was £51 and included the lines and a pair of calipers was £43, those too came of a 916 as they're the same 40mm spacing. Works a treat!
Old 08-May-2005, 01:27   #3
ali ali is offline
ali's Avatar
Mood: Damp
Ditto. Spare gold cups if you need them, go for twin disks. Not too much hassle/expense to do and they look/work much better (not that you strictly need them on a 600 ).
Old 08-May-2005, 02:18   #4
Maybe not when you've got a single caliper of the calibre of yours
Old 09-May-2005, 12:17   #5
Thanks for the help guys. I'd like one of those gold cups you have - would you like me to send some money and an SAE? If so e-mail me your address.
I'm going to pass on the front disk though. I think it's a good idea as the single disk does fade badly, but I don't know how much longer I'll be keeping it before moving onto something a little more powerful anyway, so I don't want to spend too much. I just called a dealer that's not too far away and they can get the part in seven days and it only costs £12.50 so I think I'll go with that. Thanks for the ideas though.
Rotty
Old 09-May-2005, 12:18   #6
Rotty,
Will have a dig around in the garage tonight when I get home. It's full of 600SS race bikes and a trailer at the moment so if I'm not back this time tomorrow somebody send help
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:20.
