Old 15-Jul-2003, 11:00
rear OHlins spring
Has anyone had a professional set up to their suspension, and if so by whom, and can they tell me the numbers on the spring, and their weight?
Old 15-Jul-2003, 11:14
Try Kais suspension in Atherton, or maybe Maxton, plus the other usual suspects... JHP, Harris, Techmoto, Cornerspeed, Sigma etc
KAIS - 01942 896366
MAXTON - 01928 740531
Old 15-Jul-2003, 11:18
I know where the companies are, i was enquiring specifically about the rear spring.
reason being, at jhp yesterday john said i needed to fit a rear spring of 7.5. this has i believe 75 on it. Well i have one of these, if its the one i can save myself £50+.
Old 15-Jul-2003, 11:35
Whele Whele is offline
Mood: Meditating
Andy b - not sure of your experience so I may be teaching granny to suck eggs etc....but Take care with advice from others. Make sure you set the bike up the way it suits you - Not John Hacket or the way neil Hodge has his set-up.
I fitted a heavier spring on Johns recomendation....less preload tension on a heavier spring is supposed to giving a more progressive ride response and better adjustability.
I hated the choppy ride, I spent months trying diferent adjustments with preload, rebound and compression. Eventually I went back to the standard spring.
Its a bit like the front steering head angle - some people will say ohh no leave it alone - nobody races with the steeper head adjustment. I love it, quicker turning without the rear of the bike high in the air gives me the confidence I need to get the power down early without the fear of highsiding.
We all ride a bit differenly.
Old 15-Jul-2003, 11:46
DJ Tera DJ Tera is offline
andy, is your 998S a mono or a bip?
Old 15-Jul-2003, 13:27
Its a mono, but had hyperpro rear spring when i got it. I have aquired a 75 rear ohlins spring which i suspect is a bip one, a mono being a 65.
Old 15-Jul-2003, 13:36
I've had a Mono one put onto my bip, I will go outside in a bit and check what the code on the spring says mate!
Old 15-Jul-2003, 16:50
Chaz's Avatar
Chaz Chaz is offline
Bikes: 916 Strada
Mood: www.od2racing.co.uk
ohlins spring
jhp fitted one to my 748 its 75 onit
  #9
Old 15-Jul-2003, 18:33
Cooking on gas now, got a ride height tool. adjusted my 75 spring to show 25mm thread. this gives a total sag of 30mm on the rear.
distance to datum line is 230mm for ride height. Could do with a bit more perhaps?
we shall see.
  #10
Old 15-Jul-2003, 18:45
My rear Ohlins has a 6.4Kg/mm spring fitted to it. My unit is off of a SPS and therefore meant for solo riding. Suits me on the race track with my 11 1/2 stone weight. If using a longer arm you will need a stiffer spring, if your using mag wheels you could get away with a lighter spring. Speeds envolved and types of surface will also help determine spring rating, as will the amount of available shock travel.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:38.
