Old 08-May-2005, 23:17   #1
Gav748sp Gav748sp is offline
Mood: Updating The Formula!
Socket size for engine removal !!
Can anyone help and tell me what size sockets i need to remove the engine from the frame,before i buy the wrong ones!...as mine are too big and wont fit down the tubes i cant tell what size they are.
Need to know the sizes for the swingarm one and both of the upper ones.
Thanks in advance.
Gav
Old 08-May-2005, 23:43   #2
Festa748 Festa748 is offline
Festa748's Avatar
I bought a full set of 3/8 th deep sockets from halfords and ratchet for the job and i think you need a 14mm allan ket but not sure on that but i know i hacd to buy one when i full stripped my 748
Good luck
Old 08-May-2005, 23:48   #3
keefer keefer is offline
keefer's Avatar
the spark plug socket in your bike tool kit fits in the allen key slot you are talking about
Old 08-May-2005, 23:55   #4
Carbon749's Avatar
Mood: I own a flame thrower
If it's the same as 749's your best bet is to buy a 1/2" drive 14mm and 15mm long reach socket and then use an angle grinder or similar to take a little bit more of the outside diameter of the socket. Rap the socket with a layer of gaffer tape to stop it scratching the frame when you slide it down the frame tube to reach the engine mount.
For the large allen key on the swing arm you can buy a 1/2" drive "hexagonal plug" from the motorist discount shop.
All in all, a £10 and some ingenuity will sort it.
Old 09-May-2005, 00:10   #5
748mart 748mart is offline
A usefull tip on engine removal - remove the swinging arm bolt before stripping bike. I made up a draw bolt assembly out of 8mm studding but couldn't shift the bolt until engine was run up to temperature.
Old 09-May-2005, 00:21   #6
Carbon749's Avatar
For the swing arm I made up a length of tube, used 15 or 19mm Dia tube used for a wardrobe hanging rail from B & Q.
I cut it so that it was a few mm less then the distance between the inside of the frame mounts. I used it to tap out the swing arm bolt and slid it into the swing arm and engine in place of the bolt. It kept the swing arm located to the engine, held the bearings in place and allowed the frame to be lifted up and off the engine.
[Edited on 8-5-2005 by Carbon749]
Old 09-May-2005, 00:37   #7
keefer's Avatar
engine mounts are 14mm
swing arm 20mm with the allen key on the clutch leaver side
Old 09-May-2005, 00:51   #8
Mood: aving a laff
Agree with Keefer if its late model but think smaller engine mounting bolts on earleir bikes.
Allen key for swing arm is in your official toolkit or should be.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:51.
