Old 08-Jan-2013, 17:40
dunlop0_1's Avatar
Bent frame advice/opinion
I knew the frame was possibly out of sorts so I did few checks today. Head angle/alignment seems ok but as you can see in the pictures there is a definite twist in the frame.
Is this worth repairing?
Got a quote from a local frame straighteners, £150 just to check it.
No thanks.
Old 08-Jan-2013, 18:41
You're using the wrong datum by supporting the frame from the external bosses for the engine mounts. Exact alignment of the engine to the steering head or rear suspension is not critical.
You need to check alignment of the front and rear suspension mounts by supporting the rear suspension mounts internally using a bar passing through the holes (not the external boss surface) and verify that the pin through the steering head is vertical.
Old 08-Jan-2013, 19:03
dunlop0_1's Avatar
Thanks, will do
Old 08-Jan-2013, 22:40
Yep as Shazaam says make sure the steering head is perpendicular with the actual swingarm pivot
unlike the poxy swingarm JMC made for my Harris years ago, Ok the pivot was as the frame was straight but the rear wheel spindle wasn't as they couldn't even get them aligned correctly.
Old 20-Jan-2013, 08:25
Quarrybends's Avatar
Quarrybends Quarrybends is offline
as the saying goes "pay peanuts and get monkeys" the equipment used isn't cheap and will give you peace of mind, wont be much more to jig it if bent as it's set up and in situ.
Old 20-Jan-2013, 08:36
dunlop0_1's Avatar
Of course, but it was the "about" part of the price that put me off. I couldn't pin him down to a definite.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:43.
