Old 14-May-2005, 17:31   #1
Mr C Mr C is offline
Getting things done the Keefer way
Lesson 1
Its important to choose the right tool for the job, Failing that peices of paving slab will do. Then hit as hard as you can.
Lesson 2
Sould lession 1 not achive the desired results. Just saw the B*stard off.
[Edited on 14-5-2005 by Mr C]
Old 14-May-2005, 17:44   #2
Delicate machines that need the utmost care? NUP!!!
Old 14-May-2005, 17:49   #3
Wylie1 Wylie1 is offline
Wylie1's Avatar
Does the ' C ' in Mr C stand for COWBOY by any chance??
Old 14-May-2005, 17:50   #4
And I thought a bit of paving slab was the right toll for the job, I wonder what he should have been using instead
Old 14-May-2005, 18:19   #5
Don't be daft Kev, I thought you knew your onions when it came to mechanics, and there you are, don't even seem to know that you need a Kango for that sort of job
Old 14-May-2005, 21:57   #6
keefer keefer is offline
keefer's Avatar
ok ok
so the engine was taken out by any means necessary.
but I was supplied the concrete and saw by MrC
she has been given a wee wash down (MrC do you recognise it )
and has been put in the fresh black chassis (looks good)
and ill wire it up during next week
look forward to getting it out
Old 14-May-2005, 21:58   #7
keefer's Avatar
and
Old 14-May-2005, 23:16   #8
swannymere's Avatar
Mood: High as a kite!
You look dealership trained to me
Old 15-May-2005, 00:11   #9
If i couldn't budget it with a lump of concrete and I haven't got a Kango I could try the works Hillti and if that didnt work maybe I could turn it on its side put it on the mill bed and machine it out.
And if all else fails somebody pass me the cutting torch. :P
Old 15-May-2005, 00:47   #10
DC DC is offline
DC's Avatar
Mood: Double 9, Single 6.
Originally posted by keefer
ok ok
Ohhhh you bugger!!
Your at it again.
DC.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:04.
