Old 20-May-2005, 19:32   #1
ttstu ttstu is offline
Mood: On the mend!
Clutch Spring Washer Q.
I'm about to fit some anodised spring washers to my std. clutch. I read a previous post which said to undo the bolts in a criss cross fashion and I can see why.
In my instance I don't want to take them all off at the same time as I am not replacing the pressure plate. Would it be ok to undo two at a time in a criss cross fashion? Or would this warp the clutch?
Thanks in advance.
Old 20-May-2005, 19:59   #2
Felix Felix is offline
I doubt you'll go far wrong with that.
Old 20-May-2005, 20:08   #3
The Big Red One The Big Red One is offline
Mood: Sparks will fly. If it keeps on
Do it when the bike has not been used (cold clutch) as it strips the treads so Ducati advised me. Don't do them up all that tight as 5NM is recommended. More bling. keep on Blinging.
Old 20-May-2005, 20:08   #4
Dibble
like Felix says, that will be fine, just don't overtighten them when you put them back in, as the posts can snap....
Old 20-May-2005, 20:23   #5
put a little copperslip on the bolt threads when you refit them.
Old 20-May-2005, 20:24   #6
Oh and make sure the cap your fitting is the same shape/depth as the one your taking out!
Old 20-May-2005, 21:35   #7
Mood: On the mend!
Thanks lads.
