Old 02-Feb-2013, 19:19   #1
Dyno Day with the #27 Bike
Now minus the Nemesis ECU and in its place a reprogrammed standard ECU with the IMMO function turned off
Result measured at the rear wheel on the Dave Wood Racing (DWR) Fuchs Dyno, with Junior as the Dyno operator
64.2 bhp and 42 ft lbs of torque
Click image for larger version Name:	#27 Dyno Chart.jpg Views:	716 Size:	136.5 KB ID:	13418
Old 02-Feb-2013, 20:11   #2
Awesome. Phil will be delighted
be good to see some racing this year!
Old 02-Feb-2013, 22:19   #3
So why are those two torque graphs reading approx 36 & 37 & not a 42 in sight??
Also why is there no RPM on the scale the speed means zilch we use a tacho on track.
Old 02-Feb-2013, 22:25   #4
I wondered about the rev being missing, speed instead isnt something I've seen, but sure Kev will have loads of print outs
Didnt notice the torq but very low if its sub 40
Old 02-Feb-2013, 23:11   #5
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
SeeleyG50's Avatar
Mood: The Older I get the Faster I Was!
[quote=Ghost]So why are those two torque graphs reading approx 36 & 37 & not a 42 in sight??
Read it again............
Old 02-Feb-2013, 23:17   #6
[quote=SeeleyG50]
I give up I can't see it. Also I'd like to see the rpm scale so that torque and power can be seen to coincide at 5252 RPM.
Old 02-Feb-2013, 23:19   #7
SeeleyG50's Avatar
Kev.
There's something amiss with the comparisons between the runs? I suspect that you weren't running the same gearing/gear?
Old 02-Feb-2013, 23:21   #8
SeeleyG50's Avatar
[quote=Ghost]
Scale on the right. 5.8 Kgm is around 41 ft.lb.
Old 02-Feb-2013, 23:27   #9
[quote=SeeleyG50]
Just spotted it, 5.8 calculates to 41.95 ft.lb. Who the hell uses Kg/m for torque??
Old 02-Feb-2013, 23:34   #10
Both runs done on the same gearing, the bike never left the dyno between the first run and the last, maybe one was in 5th and the other in 6th
I have another dyno sheet with just the final outcome and on that one the torque scale on the right is ft lbs and it has the rpm across the bottom scale
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:41.
