Old 03-Feb-2013, 13:41   #1
phill obbc phill obbc is offline
Bikes: cbx1000 and ducati 748 749
phill obbc's Avatar
749 light issue help please
Hi all,
i have a 749s 2006 which i bought as atrack bike, she is almost ready to use now as a track day is fast approaching.
However i have noticed that the orange EOBD light comes on after she is started ,not straight away and stays on does anyone know why, she has been lightened so anything not needed has been removed by previous owner, she seems to run fine although not been out her yet ...... weather,
i need to get this resolved asap,
any help would be great,
Thanks all
Regards Phill
Old 03-Feb-2013, 13:55   #2
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Assuming the original clocks are one the bike, press and hold the left button on the clocks whilst switching the ignition on. This will bring up the EFI fault code.
ERROR CODES
1.1 = Throttle Position Sensor (TPS) Disconnected
1.2 = Throttle Position Sensor (TPS) short circuit to earth
2.1 = Pressure Sensor short circuit to power supply
2.2 = Pressure Sensor shorted to earth
3.1 = Water Temp Sensor shorted to power supply
3.2 = Water Temp Sensor shorted to earth
4.1 = Air Temp Sensor shorted to power supply
4.2 = Air Temp Sensor Shorted to earth
5.1 = Battery Hi
5.2 = Battery Lo
10.1 = Horizontal Coil shorted to power supply
10.2 = Horizontal Coil shorted to earth
11.1 = Vertical Coil shorted to power supply
11.2 = Vertical Coil shorted to earth
12.1 = Inj1 shorted to power supply
12.2 = Inj1 shorted to earth
13.1 = Inj2 shorted to power supply
13.2 = Inj2 shorted to earth
14.1 = Inj3 shorted to to power supply
14.2 = Inj3 shorted to earth
15.1 = Inj4 shorted to powersupply
15.2 = Inj4 shorted to earth
16.0 = Pump Relay
17.1 = L/H Fan shorted to power supply
17.2 = L/H Fan shorted to earth
18.1 = R/H Fan shorted to power supply
18.2 = R/H Fan shorted to earth
19.1 = Starter Solenoid shorted to power supply
19.2 = Starter Solenoid shorted to earth
30.0 = ROM/Eprom error
34.0 = Signal Panel Sensor
36.0 = Speed sensor
37.0 = Immobiliser (transponder)
37.1 = Immobiliser (antenna)
37.2 = Immobiliser (instrument panel serial driver)
37.3 = Immobiliser (serial cable disconnected)
37.4 = Immobiliser (ccm serial drive)
37.5 = Immobiliser (key not recognised)
37.6 = Can Line error
Old 03-Feb-2013, 15:58   #3
chrisw's Avatar
Try running until the light comes on, then try to do the button/ignition thing. Alternatively, download Ducatidiag and buy the leads and you will be able to read the stored codes
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:09.
