Old 24-May-2005, 21:07   #1
Changed the front sprocket
Right, I've just been outside and changed the front sprocket on the bike and only managed to strip one thread
The stripped thread is the one that holds the sprocket cover in at the top. The bottom one is fine but in my hamfisted gorilla approach I did the top one too tight and it just kind of spins in there now - doh! What can I do to fix this?
Secondly, I've adjusted the chain and done the rear axle nuts up to 33Nm - is this right? I seem to remember hearing 77Nm for somewhere but can't place it.
And thirdly, I know the idea is to line up each adjuster on the back inline with the markings so each side is the same but it doesn't seem right when I do that. It seems like the wheel is out of line and not straight. Trust the markings and get on with it?
Old 24-May-2005, 21:22   #2
tetol tetol is offline
Mood: ok
the sprocket cover is not a legal requirement tp i would leave it off
Old 24-May-2005, 21:35   #3
I changed my gearing back to stock for my trip to S/Stone today - but wished I left it as 1 less on the front.
I did manage to pull 110mph down the straight though, but on Andy's 999R I managed 150!!!! No wonder my laptimes were cr4p!!!
I just don't think that a 620 can handle the stock gearing - I am probably better leaving the front stock and going up 1 at the back for the longer circuits I reckon?
Tim
Old 24-May-2005, 21:45   #4
Well - it's 77Nm and I'm going to get it as inline with the markers as I can and then adjust to make sure the chain sideplates look straight as the wheel rotates. May have to helicoil my hamfistedness though ****!
I agree Tim, the bike struggles to pull 15/46.
I'm going to run 14/46 tomorrow night at Brands (you going to make it?) and see how I get on. I can see me running 14/45 for CC.
I forgot about the clipons mate! Is it too late to pop down and pick them up?
Old 24-May-2005, 21:52   #5
domski's Avatar
That's what happens to you office boys when you get your fingers dirty
A bummer though
Like Paul says, don't need it for racing, and you'll probably need a heli-coil thingy to repair it. Someone like Skidlids will know what to do.
Don't do it to 77Nm!!!!!!
I did mine up to 70Nm at Cadwell and Louigi had a hell of a job undoing it coz it span the chain adjuster around and around
Just do it up with a spanner, and use the torque in your arm - bare in mind you need to be able to undo it again!!
Don't trust the markings either!!
Louigi told me to use the gap between the back of the adjuster and the hole in the swinging arm (where the spindle slides back and forward). Make the gap equal.
Does that make sense?
Old 24-May-2005, 21:53   #6
domski's Avatar
Well - it's 77Nm
Ooops!!
[Edited on 24-5-2005 by domskidue]
Old 24-May-2005, 22:12   #7
moto748 moto748 is offline
Ah, back in the days of those old-fashioned double-sided swing-arms...
On my old 750SS, I used to measure the distance (clearance) between the "shoulder" of the rear tyre and the swinging-arm, and make sure it was equal on both sides.
Old 24-May-2005, 23:49   #8
It is now!!!
Tomorrow's OK with me - just don't expect me to be too sociable when the footies on!!!
Tim
Old 24-May-2005, 23:52   #9
It is now!!!
Tim
I texted you and rang as well ... nevermind.
Are you working from home tomorrow? Because I'll be heading to Brands early to pick mw up on the way. Briefing is 5:00pm - are you going to book?
Old 24-May-2005, 23:55   #10
the old man's Avatar
Actually the DD regs say that a gearbox sprocket cover is required - though God knows why?!!
77NM/Kg/ft/lbs???? just do it up tight - but not as tight as the top sprocket cover bolt!!!!
Percieved wisdom is that alignment marks are not to be trusted - I have a pair of six foot long straight edges that I clamp either side of the rear wheel; then align the wheel so there is the same gap between the straight edges and either side of the front wheel. If that males sense; assumes the frame is straight as well. BUT I haven't bothered to use it on the 620, just used the alignemnt marks and it all seems OK to me.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:28.
