Old 26-May-2005, 00:46   #1
Trig Trig is offline
Bikes: Ducati 999, BSA A65 Lightning, Matchless G80s
Trig's Avatar
Mood: Fed up with DIY!
Dead Instrument Panel
And the tacho is stuck at 13000revs. Found a few posts on this. Seems a common problem. Need to check the fuses on the side of the headlight mount.
How do the fuse covers come off? I've pulled the individual covers but they won't budge
Old 26-May-2005, 10:09   #2
Trig's Avatar
Does each of the 4 fuses have an individual cover?
Do I need a special tool?
Is there some sort of locking tab that I have to depress before the poxy cover will release?
Old 26-May-2005, 10:51   #3
748mart 748mart is offline
Glenn, are you planning to ride to the TT? Sorry can't give you any help but hope you get it sorted ASAP.
Old 26-May-2005, 10:55   #4
Mood: Diet
Yes each fuse has an individual cover. they are a bit stiff to remove, but no special tool needed
Old 26-May-2005, 15:23   #5
Trig's Avatar
Yes Martin I am riding there - touch wood! Are you going? I will give the covers a bit more force tonight Rob and see what happens.
Thanks for the replies.
Old 26-May-2005, 15:44   #6
No i'm not going , will be DIY'ing & housey things at weekend - need to get the Brownie points for the CC & Snetterton weekends. Hope you get bike sorted & have a top weekend.
Old 26-May-2005, 15:58   #7
Trig's Avatar
I've still got a bit of time to sort the bike out because I am going on the 3rd of June. Got a wall to build this saturday! What chance have I got I can't even get a fuse cover off!!!
Old 27-May-2005, 01:22   #8
Trig's Avatar
My fuse covers have locating catches which stop them being pulled straight off. Got the fuse out and put it straight back in and hey presto everything is back to normal
Old 27-May-2005, 04:40   #9
HW HW is offline
I got a can of Wurth Silicone spray, recommended by our local Ducati dealer (they also sell it). I occassionally go around the electrical connectors that I can see with it as it is meant to be better than WD40 for keeping moisture out. THey use it in the plug caps too, with red rubber grease liberally applied around the coil seal (to complete the story).
Old 27-May-2005, 13:14   #10
1. Henry what on earth were you doing up at that hour!
2. Same as Henry here, bought some of the Wurth silicone spray last weekend after watching JHP smear grease all over the rubber seal on the coils and the spray the heads liberally with this stuff.
