Old 26-May-2005, 17:26   #1
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
Problem with new clutch
Fitted a new clutch to the 996bip '00 model
What has happened is after fitting it all together and running up the engine i noticed that the pressure plate seemed to be running out of line like a buckled wheel. Disengaged the clutch a couple off times and it ran normal. Started it again and it ran out. What has happened is the last friction plate has fallen out of the basket and not gone back in.
Should i leave out some off the steel plates or could it be i have been given the wrong basket/clutch kit. the number of plates matches up to what the haynes manual says.
Anyone else had this problem before.
Old 26-May-2005, 17:29   #2
Is this an OEM clutch or an aftermarket jobbie? The symptoms you have sound like the clutch pack is too deep and needs reducing, but if you have swapped it for the same item then something is a miss.
Old 26-May-2005, 17:42   #3
Yeah all genuine parts fitted. Thats what makes me wonder if the basket is wrong due to the number of plates being right with the haynes book at least. think i got 9 steel plates off the top off my head will have to count them when i get in the garage tonight.
[Edited on 26-5-2005 by Mello-Yellow]
Old 26-May-2005, 18:03   #4
The last plate shouldnt be a friction plate, it should be a plain pressure plate.
Old 26-May-2005, 18:09   #5
It is. The end/last friction one has jumped out should have put.
Old 26-May-2005, 18:19   #6
From memory and i could be wrong you should have two plain plates then alternate friction/ plain plates ending in a plain plate. Is the pressure plate sitting down correctly? Its should be almost flush with the edge of the basket. Did you change the basket as well or just the plates?
Old 26-May-2005, 18:53   #7
Have fitted new clutch plates and a new basket
part numbers on invoice are
19810271a clutch housing
19020013a clutch disc set
have fitted as you described 2 plain steel plates then alternate friction/steel there is also a dished plain plate 1.5 mm that i have fitted dished side out as in manual.
the last friction plate is flush with the basket then there is the last plain plate aswell, so when the pressure plate releases the plate falls out. like there are to many plates got 9 plain and seven friction (just counted them)
Old 26-May-2005, 19:47   #8
keefer keefer is offline
keefer's Avatar
I would take out one of the first plain plates so you just have one then friction plain and so on.
with the whole stack inserted there should be about 4mm gap up to the edge of the basket before you put the pressure plate on.
Old 26-May-2005, 20:03   #9
keefer's Avatar
sorry forget that I just remembered that one of those plain plates is dished (the first one)
still sounds like you have two many plates in there though, remove a friction and plain plate further down the pack and see how it fits up
Old 26-May-2005, 23:13   #10
I think you have too many plates.
I also think the 4-5 mm stack height adjustment is to do with a slipper clutch not as in this case a std clutch.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:45.
