Old 27-May-2005, 16:54   #1
adam adam is offline
Mood: happy
a great day tomorrow
I will be collecting my 996r from nellys tomorrow. its been tough without her here. Hopefully its sorted.
I do have a question what is likley to happen if i run my bike with the standard ECU in with my 50mm termis fitted instead of the performance one? nelly said the fuel mixture is ok but will i damage anything if i keep running it this way. Otherwise i might have to spend aprox £600 on a new ECU
which I dont really fancy doing.
Old 27-May-2005, 17:01   #2
Get a PCIII for way under £300 and have it set-up
Old 27-May-2005, 17:01   #3
Dibble
not the way you ride it .....
Old 27-May-2005, 17:13   #4
So was it the ECU that's at fault? I reckon there may be a few lying around if you try hard enough to find one???? Try JHP, Sigma and the like.....
As for problems with the bike, she might run a bit lean (but Nelly's view is the one to rely on), but shouldn't do any long term damage, unless you're running her at full chat all day long - depends how long your living room is - as you won't be riding her on the road will you?
You treat her good now - ya hear!!!!
Tim
Old 27-May-2005, 17:13   #5
beancounter beancounter is offline
beancounter's Avatar
Mood: Black and grey (and a bit of red)
Not the way you ride it .....
ouch
Old 27-May-2005, 18:27   #6
Mood: happy
one of these days Dibble you will be nice to me
Tim, thats what nelly thinks it is, he hasnt the equipment to check it out.
He changed the timing sensor and re shimmed it, changed the plugs then took it for a blast. No problems, until he went to start it again, then the symptoms started. I sent him the standard ECU and he has been out again and no problems. I will pick her up tomorrow and ride her around, always returning home before switching her off and re starting, as this is when the problem starts.
Is there any way to test the Performance ECU to see if it is faulty?
I am going to find it hard to take her out with confidence for quite a while, worrying that it will happen again.
Maybe the PC111 might be the way to go, ill have to wait and see what happens when I take her out for a blast.
And Tim, she IS my baby and I will love and honour her till ***** do us part.
Old 27-May-2005, 18:34   #7
HW HW is offline
How does a Power Commander connect into the circuit? It can't replace an ECU surely, as that has all the key code etc too?
Old 27-May-2005, 18:38   #8
Dibble
no such technology on the 996R's ... robust, brutal priimitive beasts that they are ....
and Adam, if i didnt like you, i wouldnt jest with you ... x
Old 27-May-2005, 18:39   #9
Mood: happy
beats me HW, all this is over my head, so need advice from all angles.
Old 27-May-2005, 18:40   #10
Mood: happy
Ahh thanks Dibble
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:46.
