Technical - Help or Info - NON Motorcycle
PC's, Internet etc. Cars, or how to fix that leaky radiator - in here please!
Old 30-May-2005, 11:32   #1
Mark Mark is offline
Mark's Avatar
IPX Driver
Quickie, I've just bought a external hard drive. When installing it says can't find an IPX file. I know IPX is something to do with networking. The hard drive was bought as it was network compatible.
Any suggestions where I can get this driver from, and also NDNS Bus, or something along those lines? This problem happens too all three pc's.
Cheers.
Old 30-May-2005, 11:45   #2
IPX/SPX is a network protocol yes, not much used these days, was used extensively in Netware.
Go to control>panel>networks/my networks on the general tab install IPX
Old 30-May-2005, 12:01   #3
tricky tricky is offline
Mood: Need spares
How does this device connect USB / Firewire or Ethernet ?
What OS are you using ?
What is the manufacturer and model ?
Cant see any sort of NAS device these days using IPX unless it has some sort of compatability with Netware 3/4. I would thing that the IPX reference is to something else.
Old 30-May-2005, 18:47   #4
Mark's Avatar
SmartDisk 'NetDisk' Network Direct Attached Storage. I'm using the Ethernet cable to my router, so all 3 home pc's can use this.
JPM, I can't see install IPX in My Networks options.
Cheers.
Old 30-May-2005, 18:57   #5
748mart 748mart is offline
Cheers.
go to your LANcard properties, select 'install', add 'protocol', select NW link IPX/SPX.
[Edited on 30-5-2005 by 748mart]
Old 30-May-2005, 19:12   #6
Mark's Avatar
Okay, I think I must be stooooooopid! When I go to the card and install and add protocol this option does not appear???
Also, Windows XP.
Old 30-May-2005, 19:41   #7
Start > Control Panel > Network Connections > Local Area Network
Click the Properties button
In the This connection uses the following items: section, click the Install button.
Select Protocol and click Add...
Select NWLink IPX/SPX/NetBIOS Compatible Transport Protocol and click OK
You're done.
Old 30-May-2005, 20:06   #8
Mark's Avatar
Ta muchie mate!
Hope you never got too wind swept this week
Okay then, how about LPX? (I'm a nugget I miss typed the ipx bit)
Old 30-May-2005, 20:23   #9
Mood: Need spares
dont know if this will help but i found the software for the smartdisk at
http://sdkbase.smartdisk.com/display...t2&r=0.8393453
Looks like it uses proprietry method of communication and not standard smb or nfs emulation over ip.
Old 30-May-2005, 21:44   #10
We were about 50 yards from the beach and it was like sleeping in a bloody aeroplane the trailer was moving about so much!
The nippers were impressed though as I managed to keep the kite in the sky, at full string length, until they got bored of it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:10.
