Old 30-May-2005, 18:32   #1
monstermob 998's Avatar
flo-commander??
surfing the interweb and found this;
http://flo-commander.com/index2.html
any body used them?or know anything about them?
Old 31-May-2005, 16:43   #2
IainMac IainMac is offline
IainMac's Avatar
Mood: I've bought a 900SL!
Hmmm It looks like it alters fuelling by restricting the air bleeds. I'd say there's no substitue for getting carbs jetted properly in the 1st place and this would be a last option solution when everything else fails... but thats just my cynical opinion.
Old 31-May-2005, 20:07   #3
paynep's Avatar
Mood: Wet wet wet
I agree with what Iain says, BUT this looks like it gives the ability to tweak as conditions require - if you know what you are doing.
Add this to the barometer/humidity/temperature gauges that tell you what the weather is like and what changes are needed and a carb setup will be as good as injection................
Tell you what, if you order them I'll try them on the flatslides and if they work I'll buy my own
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:53.
