Old 31-May-2005, 09:14   #1
DSC Member MJS MJS is offline
Bikes: None at the moment
MJS's Avatar
Mood: Feeling old...
Throttle Stuck Open
Any ideas?
Coming back from a ride yesterday afternoon, slowing down for a roundabout and realised something was wrong, engine is revving as I change gear. Seems the engine is now ticking over at just over 4000rpm. Got the bike home eventually, although riding through town was entertaining every time I had to stop at traffic lights! Bike ran very hot coming back into town, although that may have been due to the fact I was limping along in 1st gear..
Throttle movement is no different to normal... Any suggestions?
Martin
Old 31-May-2005, 10:25   #2
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
First stop - check the cable adjuster on the top of the throttle-grip housing - someone may have helpfully adjusted it for you when the bike was parked up.
Spinoli
Old 31-May-2005, 10:39   #3
MJS's Avatar
Spinoli
No - it was fine when I set off, something happened on the way back.
Old 31-May-2005, 12:34   #4
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mello-Yellow's Avatar
Mood: When's the sun coming out
Could well be a fraid cable, The inner wire cable sticking to the outer one somewere inside.
Old 31-May-2005, 20:41   #5
Scotty Monster Scotty Monster is offline
Scotty Monster's Avatar
Mood: counting
humm id go for frayed cables
happened to me once in stafford in front of a police car of course pulled clutch in in traffic and the engine started reving its tits off then sorted its self out later but soon after i had to replace a frayed throttel cable
Old 31-May-2005, 21:27   #6
mikecardiff mikecardiff is offline
Might seem obvious, but you didnt accidentally get the warm up button stuck on did you ? this would make it idle at 4000rpm - to get it off you need to fully close the throttle hard and it will pop back out.
Just a thought when I saw you had mentioned 4000rpm
Mike
Old 31-May-2005, 21:58   #7
ducati996dude ducati996dude is offline
Mood: Always happy on my Ducati
I would also go for a fraid cable, but also check that the cable has a free passage and is not caught up in anything, I had a motox do the same thing only to find that the cable itself had lodged itself between rad. and frame, everytime I turned the revs increased!
Old 11-Jun-2005, 21:18   #8
MJS's Avatar
Right, finally got round to having a look at this.
I've had the fairing off and checked the cable, and there's nothing wrong with that. The cable pulls cleanly and the quadrant on the throttle opens, but when the throttle is released, the cable goes slack and the quadrant stays stuck open. I can close it by hand, seems that it only sticks if it opens more than a certain amount.
I've given the springs on both front and rear a squirt of WD40 to see if that will free them up, but it doesn't seem to have made much difference so far - going to try again tomorrow...
Any more suggestions before I take it in to Riverside?
Martin
Old 11-Jun-2005, 21:24   #9
crm250 crm250 is offline
crm250's Avatar
Mood: Firing on all 4 !!
I had this on the 916, cable was fine, but as described the throttle flaps stayed open and would return very slowly.
i found where the springs are near the butterflys they were all full of crud, and a clean and light oil soon sorted that on both butterflys / springs.
hope this helps
Old 12-Jun-2005, 01:18   #10
Mood: aving a laff
Same happened to me on the track bike.
at the side of the throttle bodies is a plastic knuckle with a ball ended rod in it to operate both the throttle bodies at once.
This had become sticky but a quick squirt of brake cleaner and some WD40 into the knuckle sorted it out and no more sticking throttle.
Worth a try?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:40.
