Old 15-Feb-2013, 19:57   #1
mattslade mattslade is offline
mono small triangular pad
Hi,bought a mono seat unit but its come without the small triangular pad, there are two round velcro type discs riveted in, and the pad I've got new from ducati has two of these that screw into the pad,my parts cd disc doesnt show it as there being 4 and them velcroing together surely this wouldnt be very secure in anycase? My thoughts are that i need to drill out the existing ones and put the new ones on the other side and screw the screw through the hole in plastic into the pad to hold it but if that's the case why are they velcro looking
Old 15-Feb-2013, 20:12   #2
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
Yep, it's held in place with some really stiff velcro type stuff. The seat should have two pop rivetted on. The pad itself should have two discs pop rivetted into it. It is a surprisingly strong fastening system.
Old 15-Feb-2013, 20:33   #3
My pad ones are unscrewable when i unscrewed both of them and offered up the pad it fitted much better which was one of the reasons i thought there should only be one pair,also with the disc bit out of the pad no matter how hard i press it won't hold at all but this might be down to the discs riveted to the seat being worn.
Old 15-Feb-2013, 20:37   #4
Wasn't pushing hard enough all sorted now thank Christ i didn't drill the rivets in the seat, cheers for you help
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:08.
