General Motorcycles only
Old 31-May-2005, 21:33
ttstu ttstu is offline
Mood: On the mend!
Understeer Problem
Went out with a couple of fast lads at the weekend which allowed me to push the bike harder than I have up to now. I noticed and so did the rider following that my 999 was understeering into corners. I think more noticable on left handers although that probably isn't too relevant.
At one point on a left hander at the apex of the corner I'm almost out to the white line with the bike almost on it's side to stop drifting out further! Bit scary and not what I'm used to.
Part of me is thinking perhaps it is me as I'm aware the bike handles less well than the Mille. But I also think it is the bike.
What do I need to do to get her to turn in better and give me better feel from the front tyre?
Old 31-May-2005, 21:36
nathanhu's Avatar
nathanhu nathanhu is offline
Mood: head down
ttstu, what bike do you ride?
Old 31-May-2005, 21:39
Mood: On the mend!
Sorry 999 BP '03.
Old 31-May-2005, 21:54
Monty's Avatar
Jack up the back by about 10mm at a time testing after each change-that should do the trick. It worked on my 996 and also my ST4S-now that used to really understeer, especially on the gas-it doesn't now.
John
Old 31-May-2005, 22:09
nathanhu's Avatar
Mood: head down
have you done any suspension adjustments ??
and how heavy are you???
Old 31-May-2005, 22:40
Mood: On the mend!
14.5 stone. I've tweaked some of the settings to firm them up. The two screws on top of the forks and the two at the bottom.
I think the back end is too low and not enough weight over the front. Seems ok at lower speeds but the faster you go the more the front end wants to drift wide.
Old 01-Jun-2005, 13:16
andys 900ss's Avatar
Lifting the rear always seems to help both mine are raised, the UJM is in the sky!!!
What tyres/pressures you running? Try taking out 1-2psi out the front, I do this on trackdays to balance front/rear grip.
Andy
Old 01-Jun-2005, 18:39
GsxrAge's Avatar
GsxrAge GsxrAge is offline
Have you got a 190 on the rear or a 180 ?
Go for the 180 as they sorted out the understeer on the 9**
  #9
Old 01-Jun-2005, 22:17
Mood: On the mend!
Got 180. Think I need to drop the forks thru' the yokes. Or perhaps raise the rear? Perhaps I need to take her into a specialist.
  #10
Old 01-Jun-2005, 23:02
GsxrAge's Avatar
try the front first mate
I know this might sound obvious but have you checked your tyre pressures ?????
[Edited on 1-6-2005 by AGE996]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:30.
