Old 02-Jun-2005, 18:58   #1
Mr_S Mr_S is offline
Clutch lever travel - adjusting
Typically I ride with 2 fingers covering the clutch ( and the brake), and there's something starting to bug me, after 15 months of ownership.
Whilst riding, I can happily slip the clutch and control the speed in bends, filtering etc this way, and even disengage the clutch enough for a stop at lights etc.
But...
To disengage the clutch enough to change down a gear, I have to move the other 2 fingers out of the way, as the lever hits my fingers and stops coming back far enough. Which is annoying. Now it's done this with both clutches I've had fitted, fluids fresh, bubble free, and I've got the span adjuster set to max.
So, what if anything are my options?
Adjust the lever contact point on the M/C?
Different M/C? - Pricey though for an annoyance to be fixed
Some other adjustment?
Accept it, and adjust riding style?
I've already excluded a new slave cylinder as this increases lever travel.
Oh, and I already use clutchless upshifts, but I'm wary of clutchless downshifts on the 748, even when done properly so always use the clutch to shift down.
Old 02-Jun-2005, 19:04   #2
Slipping the clutch in bends? New one on me!
I think your only option is a different master cylinder, as the standard one doesnt have adjustment like that.
Old 02-Jun-2005, 19:08   #3
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Yep, you'll need a different ratio m/c unless you can move the lever out a bit more with the dial adjuster.
Be careful adjusting that screw in the lever cos you might end up with the piston not coming all the way back, then you'll be slipping the clutch everywhere!
Old 02-Jun-2005, 21:52   #4
All about slow speed control, fast bends it's a no no, but slow stuff, all the time. Try a feet up U turn without using the clutch, that gives you some idea of how I use it.
Now, maintaining front brake in the bends is the new thing to do (apparently stops chatter) and very scary too
Looks like I'll be either changing my ways or changing the M/C then.
Anyone know what the current standard M/C ratio's are?
[Edited on 2-6-2005 by Mr_S]
Old 06-Jun-2005, 15:02   #5
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
Are you running a standard clutch?
I seem to remember comments that some slipper clutches require a longer clutch push-rod.
Just a thought.
Spin
Old 06-Jun-2005, 18:40   #6
mikecardiff mikecardiff is offline
Could you not bend out the last couple of inches of the lever away from the bar - so the main part is in the same place and you can reach it with two fingers, but when pulled fully in, the end wont foul your fingers ?
Might be an easier fix than chaging cylinders or clutch etc...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:01.
