Old 02-Jun-2005, 23:42   #1
miltaryman miltaryman is offline
a lil more mechanical advice...thanks Iconic & everyone else...
thanks Iconic...
I changed out the fuel filter & started her up before I installed the petrol caps back(so I can see if everything looked right).
It quickly filled the filter back up w/fuel, but I noticed some bubbles coming up from underneath the fuel pump....somewhere between the pump & the bottom lower wall of the tank...not sure if it was from vibration or what.
Is that normal?
thanks anyone
joe
Old 04-Jun-2005, 23:21   #2
Hmmmm.....having drained the system, there MUST be some air in there to be displaced but - I'd have thought most of it would go forward to the carbs. I guess some could be trapped in the tank gubbins.
As long as this bubbling does not continue I would not worry too much.
Puts on his best Macho voice " Just go out and thrash it for a while Marra"!!!!
Frank
Old 06-Jun-2005, 08:28   #3
Bikes: ST4S
Mad Dog Bianchi's Avatar
Have you checked the fuel vent tube. Great little piece to look over, but oh so important. A small kink can limit the amount of full that can get sucked out. Just a thought. Also, the accelerator circuit on the carbs may be dirty leaving you high and dry at the light, but ready for normal launches.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:42.
