Old 20-Jul-2003, 07:13   #1
den den is offline
996 BP Running problems
went out yesterday after being laid up for 3 weeks and it ran like a bag of s***e missfiring throughout the range topped up fuel about 3/4 of a tank even worse went home it died on me
it will fire up but dies off right away had the fuel pump and filter replaced prior to going away and everything was running fine any ideas ?? ta
Old 20-Jul-2003, 10:12   #2
Felix Felix is offline
Sounds like it might be fueling related. Does the fuel pump whir for a few seconds and then shut off, when you turn on the ignition (but not start it)?
Old 20-Jul-2003, 10:43   #3
den den is offline
yep
whirs away quite happily then stops the tank has also been cleaned out to take out any water floating about
Old 20-Jul-2003, 18:00   #4
Yellow Bip Yellow Bip is offline
Mood: tired!!!!!!!!!
hello mate had similar problem after i high sided 99 996 bip eventually sussed out that the block connector to the computer (ECU) had come loose at one end not creating a full circuit, also had similar problem on CBR 600 and that was voltage regulator.
hope this helps.
Old 27-Jul-2003, 12:08   #5
den den is offline
problem sorted turned out it was the throttle pot running like a dream now
keep up the good weather
Old 28-Jul-2003, 20:40   #6
den den is offline
weeksy
are you saying you had the fuel pump to bits ?? I was told this wasnt a servicable item and had to be replaced the fault was eventually traced to the throttle potentiometer which was replaced and everything is running fine again no probs with the dealer as the last episode was FOC but maybe I should start fiddling myself could be a bit scary eh !
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:11.
