Old 20-Jul-2003, 20:51   #1
Jasper Jasper is offline
Jasper's Avatar
996R/998R(maybe 748R)-pic wanted
Those of you that are lucky enough to have a 996R or 998R(maybe 748R),would one of you(RAY,GUY?))be kind enoug to send me a pic of the side of the fairing where the fuse box is(or the other side),it is where the cut out with the grill mesh is.I am trying to put some on a 998 fairing and need to see if it is tapered to the fairing edge or square(Does this make sense?).E-mail me and i will send a pic!
Old 20-Jul-2003, 20:58   #2
Guido's Avatar
Rich,
Have a look at my site via the link below..
If a decent enough pic aint there, drop me an email or call and I will pop into the garage and try and take what you want mate.
HAVING SAID THAT......just re-read your post and think mine won't be much good. I have the 2001 model and that has the fairing with the cutouts on the side and hence doesn't have the grills you're after.
Over to you RAY.
Gc
http://freespace.virgin.net/guy.cope/images748r.htm
[Edited on 20-7-2003 by Guido]
Old 20-Jul-2003, 21:43   #3
Murray Mint's Avatar
Guido
I see from the pic's on your site that you've some crash protectors fitted. The reason i mention this is that Pro V Twins said that it's not such a good idea as they could lead to a bent frame for worse in the event of an off. Anybody got any thoughts on this as it dose seem like a good way to save the worse of the damage if droped.
Murray Mint
Old 21-Jul-2003, 09:58   #4
Guido's Avatar
Murray Mint,
There are two main types of protectors for the Dukes.....
One that mounts on brackets that are basically 'clamps'. These grip around your trellis frame. I wouldn't recommend them cos it's obvious what's gonna happen in an off.
Mine are the stronger type by Cyclecat.
You replace the engine mount bolt that goes straight through the battery box (on the 748/9** models) with a new item that has collars on either end. The 'bungs' then screw onto these collars.
In an off, they aint going anywhere. If they do, the frame would be the last of my concerns. The engine block is the main stress member.
They do work...I tested them at Croft 2 weeks ago. No engine, battery, clutch, or tank damage and very minimal fairing damage.
I only 'plan' to do lowsides. I don't crack the throttle wide open, so highsides will be rare.
Of course if you highside and launch the bike 3-4 feet in the air then again, I think the bungs will be the last of your worries. Dodging the asteroid-like debris would come first.......
Guido
Old 21-Jul-2003, 10:14   #5
Ray Ray is offline
Ray's Avatar
Jasper,
I will e-mail some piccies direct when I can. Will take a few measurements as well.
If you need em urgent have a look around www. ducati.com at the 2002 bike specs, they have some reasonably good piccies.
Ray.
Old 21-Jul-2003, 10:45   #6
Jeremy 748R Jeremy 748R is offline
Is this any help?
It is 200mm by 45mm.
Jeremy
Old 21-Jul-2003, 11:47   #7
Jasper's Avatar
Just what i wanted,cheers!
Old 21-Jul-2003, 11:50   #8
Jasper's Avatar
Guy,do your crash bungs unscrew so that you can put standard bodywork back ou,without having to mess with the bolts etc?
Old 21-Jul-2003, 19:05   #9
Guido's Avatar
Yup,
Sure do!
Gc
Old 21-Jul-2003, 21:09   #10
Jasper's Avatar
how much?and from where?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:17.
