Old 09-Jun-2005, 02:33   #1
the old man's Avatar
Full Monty Big Bore?
More of a question really; is anyone running a big bore that fully exploits the regs', ie., shorter inlets, bigger carbs, squish clearances optimised, cams degreed in etc?
Old 09-Jun-2005, 09:19   #2
DSC Member AK AK is offline
AK's Avatar
std carbs etc on ours
oh, and we have shortened inlets & the squish has been done (please can someone tell me what that is? )
AK wants to do mucho more, but hands are mostly tied by the reasoning that none of the parts from the engines in the series are interchangeable
C
[Edited on 9-6-2005 by CK and AK]
Old 09-Jun-2005, 09:23   #3
ali ali is offline
ali's Avatar
Mood: Damp
I think Paul Payne is running the best setup BB at the mo. He's running FCR39s and Malossi short manifolds, but I can't remember if the exhaust manifold is standard or not, and I've no idea if the cams have been set, ignition modified or squish set.
Ali
Old 09-Jun-2005, 09:31   #4
I think you will find Paul Payne (Paynep) is running near enough the spec you mention, his bike certainlt seemed quicker at Castle Combe with the individual smoothbores now in place on short Mallossi manifolds. It has been set up by Moto Rapido so it should be one of the best BB bikes out there. But is still seriously compromised by the 400SS cylinder heads that are fitted to the 600s and are very restrictive on flow with there undersized valves etc.
Tony Brancatto says there is a lot he can do with my 583 engine and get a lot more power from it, sadly most of the mods are outside the rules,
I know Paul would like to try his 750SS heads on his 674. It would be interesting to see the results.
Old 09-Jun-2005, 09:35   #5
Should point out that I do believe that a 674 BB bike with the smoothbores and some head work, but standard cams would be a match for a 5-speed 620 with a pipe filter and some fuel mapping..
6 speed versions have yet another advantage
Old 09-Jun-2005, 09:41   #6
It would be very interesting - as the 750 belongs to his wife!!!!!
Old 09-Jun-2005, 15:01   #7
paynep's Avatar
Mood: Wet wet wet
Without wanting to give everything away, I will say that my bike is totally within the rules (including std flywheel !!!!) - with BB, Keihin FCRs, squish set by using a thinner base gasket, cam timing has been done but may be experimented with, and I'm running a std 2-1 manifold and what looks to be a very old DP exhaust can.
However there are a few things that haven't been fine tuned yet, so I expect to get a little bit more out of it yet.
Cheers, Paul
Old 09-Jun-2005, 15:16   #8
AK's Avatar
can you tell me what squish is please ?
C
Old 09-Jun-2005, 15:26   #9
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Charlotte,
It's what happens when you put 15 people in a 10 person lift.
Old 09-Jun-2005, 15:28   #10
Cheers, Paul
Ok, cool. Give us a number
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:37.
