Old 12-Jun-2005, 18:08   #1
Bungi Bungi is offline
916 only reving to 7k
ive picked up a 916 thats not been used for a while.
she stars ticks over and runs a little lumpy til about 3k then its like the other cylinder kicks in (although it must be running on both otherwise it wouldnt pull away) till 7k then there is just loads of throtle left but no revs left if you know what i mean.
at 7k when you wind the throtle open further it just sound like loadsa air intake but no positive engine reponse. wont clear knocking down gears etc
plugs look ok in the centre rear pot has a slightly black outer ring. i guess this is the fist thing to change but wondered if anyone had any further pointers
Old 12-Jun-2005, 18:49   #2
How long since it was last running? If its been a while i would change the cam belts before i even started the thing.
Anyhow, our monster was running on one for a while (in the garage) and i only realised when i noticed that the exhaust pipe was stone cold!
Could the petrol have gone off and gummed things up?
Old 12-Jun-2005, 19:20   #3
ericthered40's Avatar
Mood: renegade sexy racer
I wouldn’t ride it until you get it in for a belt service.
Sounds like bad fuel but if a belt goes you’ll be looking for an engine.
Not a good idea to test ride a badly running Ducati hoping it will clear.
Standing not used they do not like.
If you don’t know what’s wrong find a man who dose before it turns in to a very expense mess.
Old 12-Jun-2005, 19:29   #4
weeian weeian is offline
Mood: 2 for 1 mmm :)
Wise Words.
/ian
Old 12-Jun-2005, 23:33   #5
belts yes iknow belts belts belts
im thinking the injectors may be suffering from standing with the fuel
will they need to come out to clean them or is there a chance i can run some injector cleaner in the fuel/ any thing wrong with this as an idea?
Old 14-Jun-2005, 21:05   #6
simply a dodgy spark plug all is sweet now
Old 14-Jun-2005, 21:09   #7
so did you get your belts done?
Old 14-Jun-2005, 22:29   #8
maybe
Old 14-Jun-2005, 22:41   #9
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:46.
