Old 14-Jun-2005, 00:05   #1
Trig Trig is offline
Bikes: Ducati 999, BSA A65 Lightning, Matchless G80s
Trig's Avatar
Mood: Fed up with DIY!
Instrument Panel Flcker
I noticed that at night the LCD and rev counter light flicker while the engine is idling. Is this normal?
Old 14-Jun-2005, 00:19   #2
Loz Loz is offline
Loz's Avatar
Not on mine!
Trouble at mill, I think, but I don't know what kind of trouble ...
Old 14-Jun-2005, 21:19   #3
ttstu ttstu is offline
Mood: On the mend!
Not had that problem (yet). I've got the mph going crazy and once the rev counter was showing 0 revs when the engine was idling at about 1100.
I guess they all do that sir.
Old 16-Jun-2005, 09:23   #4
bagonails bagonails is offline
I hav'nt had that problem. But I did have the rev counter/ speedo pack up. Switched the ignition off then started it up again and all was fine.
Old 16-Jun-2005, 10:37   #5
guest1 guest1 is offline
Are you sure it's not being "clouded"?
When the ambient lighting changes, the illumination level of the instruments change - can be seen when you are driving in sunlight with your lights on and you go under a bridge or tunnel, the lights come up brighter after a split second.
Old 16-Jun-2005, 11:26   #6
Trig's Avatar
I had this as well but I had to remove and reinsert the fuse to get over the problem.
Old 16-Jun-2005, 11:32   #7
Trig's Avatar
No it definitely isn't due to lighting changes. It flickers far to quickly and only happens at low revs.
Old 16-Jun-2005, 12:37   #8
Sure mine flickers a tad also... but never given it a second thought, only notice it in low light, and as I haven't got any lights I don't ride that much in low light anyways
Old 16-Jun-2005, 23:32   #9
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Mine did the same as yours !! But not all the time... Never got to the route of the problem !! Just sold the bloody thing
Old 16-Jun-2005, 23:52   #10
weeian weeian is offline
Mood: 2 for 1 mmm :)
just got new clocks fitted to my 749 as the speedo goes mad above a tonne.
/ian
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:19.
