Old 15-Jun-2005, 14:47   #1
everton
Clutch plate stack height.
My new clutch plates have arrived and now I have plenty of thicknesses to play with.
To get my stack height to 36.5mm I have the following order =
From the cranckcase outwards -
1 Steel 1.5mm
2 Friction
3 Dish - dot facing pressure plate
4 Friction
5 Steel 2mm
6 Friction
7 Steel 2mm
8 Friction
9 Steel 2mm
10 Friction
11 Steel 2mm
12 Friction
13 Steel 2mm
14 Friction
15 Dish - dot facing crankcase
16 Friction
17 Steel 1.5mm
This gives me a perfect 36.5mm according to my Vernier
Does this order sound OK before I re-assemble?
I'm thinking of the two 1.5mm at either end of the stack or should they be towards the centre with 2mm steels at either end?
[Edited on 15-6-2005 by everton]
Old 15-Jun-2005, 14:52   #2
Dibble
thats about the same height as a Desmondo ..... !!!
Old 15-Jun-2005, 15:38   #3
Not sure about starting with a steal plate at the back of the clutch, the second hand JHP one I have just fitted to the Hybrid was like that when I got it and that steal plate looks a bit of a mess. The recommendation I got the other week for setting-up the JHP clutch included starting with a Friction plate
also recommended here http://www.yoyodyneti.com/detail.aspx?ID=903
Kev
Old 15-Jun-2005, 15:52   #4
Felix Felix is offline
Not sure it's applicable but the factory 999RS manual recommends (from the crankcase outwards):
Fit the set of clutch plates (18) in the following order:
- 1 sintered plate (A);
- 1 convex plate (B) (convex side facing outwards);
- 1 sintered plate (C) ;
- 1 flat plate (D) (1.5 mm thick);
- 1 sintered plate (E) ;
- 1 convex plate (F) (convex side facing inwards);
- 1 sintered plate (G) ;
- 1 flat plate (H) (1.5 mm thick);
- 1 sintered plate (I) ;
- 1 convex plate (J) (convex side facing inwards);
- 1 sintered plate (K) ;
- 1 flat plate (L) (1.5 mm thck);
- 1 sintered plate (M) ;
- 1 convex plate (N) - (convex side facing outwards) ;
- 1 sintered plate (O) ;
- 1 flat plate (P) (1.5 mm thick);
- 1 sintered plate (Q) ;
- 1 flat plate (R) (2 mm thick).
Old 15-Jun-2005, 16:06   #5
As they recommend it
http://www.azionemoto.com/tech002.htm
Old 15-Jun-2005, 16:11   #6
neil748r neil748r is offline
If it's a slipper then you need to use a friction first.
If not, when the clutch "ramps" the first steel can drop off the back of the drum and jam everything up big style.
Old 15-Jun-2005, 16:39   #7
Just like it did on Dallas's 748RS at Mallory, first race meeting in 2003, Morning warm up he got as far as Edwinas.
Old 15-Jun-2005, 19:36   #8
everton
Yes, all the manuals suggest fitting a friction first but I ran this clutch for 4K miles with a steel first as recommended by Nelly and it worked fine.
Another point - the standard DP pack comes with mainly 2mm steels and only 2 X 1.5mm steels and 2 X dish plates.
Old 15-Jun-2005, 22:47   #9
I think your confusing yourself big time asking so many!
Id ring jhp, tell him what ive got and ask him.
Old 16-Jun-2005, 08:15   #10
bagonails bagonails is offline
I fitted mine how they were stacked in the box. I took them out of the box first of course!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:23.
