Old 16-Jun-2005, 00:36   #1
Redsps Redsps is offline
Redsps's Avatar
SP4, SPS, SP5 , Racing tech questions.
Now that I'm on a mission for parts I need to clear up a few questions that are bugging me.
On my quest for parts, i've been told several different versions on what the spec on the SP4/SPS/SP5 and racing are.
Now then, is the sps the identical engine lump as the sp5, and corse engine.
I've been told from varing sources that the SP4 has major internal differences, so parts are out there.
Also there seems to be varying answers as far as the SP5 is similar to SPS but there are subtle differnces to heads and valves, also possibly revised pistons etc.
SPS seems to be closer to corse engine than road SP versions.
any chance of getting a correct breakdown on specs guys.
at worse case, if I can't source SPS parts, I need to be sure parts from the other version will match my existing unit.
If not I'm looking at having to replace a lot more parts if they are even a little bit different, if you get my drift.
any SP5 or corse part number would be really helpfull etc.
Jasper, any thoughts mate on spec.
cheers
robin
Old 16-Jun-2005, 07:25   #2
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Robin, have you posted this question on the US board. Mike C and Marvin J are oracles on these bikes.
Rgds, Rob
Old 16-Jun-2005, 12:16   #3
Felix Felix is offline
What displacement does your SPS have?
Old 16-Jun-2005, 13:42   #4
yellow916 yellow916 is offline
Robin
Agree with Rob, contact Mike Cecchini et al on the Yahoo group.
Andrew
Old 16-Jun-2005, 16:32   #5
Rob B's Avatar
Ah, sneaky, two posts. I thought I was loosing it but it was 6:30am when I was posting replies.
Rgds, Rob
Old 16-Jun-2005, 18:54   #6
Redsps's Avatar
rob, decided to use the two pronged approach, but I am getting there slowly.
cheers
Old 16-Jun-2005, 20:13   #7
Rob B's Avatar
Good man, and good luck too.
Old 16-Jun-2005, 21:39   #8
Jasper Jasper is offline
Jasper's Avatar
As far as i know,the SP5 is the SPS engine with the Sp4 cooling system.I have trawled through all my Ducati books and engine wise there seems to be no difference.Same cams,rods,compression,valves etc.That's all i can offer you i'm afraid.
Old 16-Jun-2005, 22:12   #9
Redsps's Avatar
thanks for your help jasper.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:47.
