Old 12-Mar-2013, 19:31   #1
Jasper Jasper is offline
Jasper's Avatar
SS Alternator Rotor
Can someone tell me if there is a spacer that goes between the rotor and flywheel on an SS? Looking at trying to run a smaller alternator on the SP5 and the SS one is smaller and looks like it will fit the bill.
If the answer is yes, does anybody have the dimensions and/or pic? Or even a spare spacer(if there is one).
Cheers,
Jasper
Old 12-Mar-2013, 19:42   #2
Cheers,
Jasper
I have just replaced one on a 583 SS and can confirm there isn't a spacer.
Old 12-Mar-2013, 20:10   #3
Jasper's Avatar
Thanks mate.
Old 13-Mar-2013, 17:09   #4
Seems not on the 900 as well, Jasp:
Old 14-Mar-2013, 22:37   #5
Jasper's Avatar
I think the spacing difference is taken up in the flywheel. Here are the two to compare:
888
Old 14-Mar-2013, 22:40   #6
Jasper's Avatar
750ss
Old 15-Mar-2013, 21:02   #7
paynep's Avatar
Mood: Wet wet wet
Hi chaps, I've found a rotor that measures 76mm diameter, 46mm deep with 19mm hole. Is this from a 2V or 4V motor?
Cheers, Paul
Old 15-Mar-2013, 21:15   #8
Jasper's Avatar
The 888 one is 49mm.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:49.
