Old 13-Mar-2013, 22:49   #1
millesteve millesteve is offline
Calliper bracket
Hi does anyone know where I can get the adapter brackets that will let me fit 4 pad callipers with 65mm centres on my 1997 916 with 40mm mountings. And are the 4 pad callipers from a 999 and some RSVs the same as 996s/998s thanks for any help
Old 14-Mar-2013, 09:45   #2
Thumbs up
Did a quick Google for you and found these:
CORSE DYNAMICS Axial Caliper Adapters: 65mm to 40mm, $129.99
http://motowheels.com/i-8518113-cors...m-to-40mm.html
SHOWA caliper adapter (40 mm to 65 mm caliper bolt on distance) , €139.00
http://www.performanceparts.de/en/br...ce.html?lang=1
Yoyodyne - Brembo 40mm to 65mm adapters, $199
http://www.yoyodyneti.com/category.aspx?categoryID=2954
All essentially the same thing.
As an alternative, why not change the forks, or just the fork bottoms for the correct mounts?
As for the calipers, they are supplied by Brembo to lots of manufacturers, including Ducati and Aprilia, so they will be the same.
Old 14-Mar-2013, 13:46   #3
These good guys too:
http://www.ducati-kaemna.de/cms_en/k...el&artikel=234
Only available in gold at the moment apparently - EUR 139
Calipers to look for are P34/4 and yes I've used a pair from an RSV-R on my ST4s, work very well but you might need to factor in new hoses if the banjo mounting point is different to your existing - P4's mount to the side:
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:24.
