Old 20-Jun-2005, 12:38   #1
neil748r neil748r is offline
Headstock bearings?
Hi Guys,
Does anybody have any part numbers for headstock bearings and seals? NOT Ducati's part numbers but the bearing manufacturer's own numbers.
Spoken to SKF this morning and it's a discontinued part so Ducati must now source from some other manufacturer.
Any clues?
Cheers, Neil.
Old 20-Jun-2005, 16:41   #2
Timken bearings: L44613 (race) and L44645 (the bearing)
(Being the best tapered bearing on the planet, Timken bearings are not cheap.)
Also, SKF 639174 and 639172
[Edited on 6-20-2005 by Shazaam!]
Old 20-Jun-2005, 17:21   #3
Felix Felix is offline
If you get on to a good local bearing supplier/distributor they should be able to cross-reference the SKF part numbers for you. Also, have you tried places like B&C Express?
Old 20-Jun-2005, 17:22   #4
Thanks Shazaam!
A bit of clarification needed though. The part numbers you quoted are for tapered roller bearings, the Ducati OEM bearings are single row angular contact bearings (SKF BA1B 311705 - discontinued).
So are you saying that the numbers you quoted are a direct replacement? I found reference on the net to them being suitable for a Paso, but not sure they're the same as 748R?
Cheers, Neil
Old 20-Jun-2005, 17:29   #5
Tried that already Felix.
Problem is as it's a discontinued SKF part, it doesn't appear on anybody's database so they can't make a comparison.
Old 20-Jun-2005, 17:49   #6
Neil, can't you just give the bearing supplier dimensions? Usually works for the one I use, if I don't have a part number.
Old 20-Jun-2005, 18:03   #7
My notes say that they're a direct replacement for 916 series based bikes. Sorry, I was assuming that they are the same as 748R.
Are you SURE you need to replace the bearings? Take the steering stem off the bike and look at the bearings. If they are not pitted or dented thay are most likely fine. Is the preload adjusted properly? I usually adjust them so there is just a little preload. Do the clamps move freely without binding? 1.e. if you lift the front wheel off the ground do you feel a notch while turning the wheel back and forth?
It's just unusual in my experience for a newer bike to require a bearing replacement so soon.
Old 20-Jun-2005, 18:09   #8
You're not a wheelie master are you?
Old 20-Jun-2005, 18:11   #9
Thanks again Shazaam, to the best of my knowledge the 748R bearings are the same as all the other 748/916 derivitives so they should be fine. Only thing I'm not certain about is whether the non-adjustable steering head angle bearings are the same as for the adjustables. I'll have to double check that.
And yes, they're definitely shot, rusted, pitted etc etc.
Old 21-Jun-2005, 07:40   #10
As far as I am aware the bearings for adjustable & non adjustable headstocks are differant, i would check with a Ducati dealer, top & bottem bearings for a 748e are around £23 each top & bottem.
Chris.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:46.
