Old 20-Jun-2005, 19:17   #1
khu996 khu996 is offline
khu996's Avatar
What the feck?!
Just got back after a weeks holiday to find a replacement slave cylinder, so got to fitting it and giving the bike a little clean, when I come across this:
From a slightly different angle:
What the feck has happened here, and do I need to sort it? Does it have something to do with the leaking clutch fluid on my last ride?
Its a standard 14t on a pretty standard 749 bip, as far as I know the sprocket has never been removed/changed.
Old 20-Jun-2005, 19:21   #2
Sorry mate,you've lost me.What gives you cause for concern?
Old 20-Jun-2005, 19:22   #3
guest1 guest1 is offline
Give us a clue, is it the JAPAN on the chain?
Old 20-Jun-2005, 19:23   #4
I know I know I know (raising hand in air)....it's a sprocket!!!ta-daaaaa
Old 20-Jun-2005, 19:25   #5
Gizmo Gizmo is offline
Mood: is it the weekend yet??
i know its strange to still have the nut on but it is meant to be there
Old 20-Jun-2005, 19:26   #6
bolds bolds is offline
All looks perfect to me-apart from needing a clean
Old 20-Jun-2005, 19:28   #7
On further examination it is apparent that gosh OMG...JAPAN is the correct way up on one link, but upside down on the next link. Could that be the answer?
apart from that, nothing jumps out at me from those pictures.
Old 20-Jun-2005, 19:28   #8
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
the washer is ment to be bent over like that stops the bolt coming undone
if thats not what your on about. god knows
Old 20-Jun-2005, 19:29   #9
khu996's Avatar
Perhaps its me being a ****, but I never noticed the 'fold' in the washer (or whatever it is) behind the nut!?
Sorry lads!
Old 20-Jun-2005, 19:29   #10
Felix Felix is offline
I know, I know: NO CHAIN LUBE! It has magically disappeared!
Sorry, mate, if you're referring to the bent washer, it's meant to be that way. Otherwise, I am as baffled as the others.
