Old 22-Jun-2005, 09:25   #1
iky8705 iky8705 is offline
im buying a 2001 748 and had a quiestion
Well I am in the process of buying a 2002 748 but thier was one thing that was bugging me about the bike. Im not sure if thats just how it is or if it just needs to be repaired, but whenerver you hold the clutch down i hear a high pitch noise. the guy has some type of clutch cover, and said that was the reason but i wanna know what you guys think
Old 22-Jun-2005, 09:47   #2
weolcome abouard!!
Have you heard another one to check it against? There is a bit of 'they all do that' when it comes to clutch noise so best to gauge against another if you can..........sure someone technical will be along in a bit with info
Old 22-Jun-2005, 10:20   #3
If anything the noise should reduce when you pull the lever in. My guess would be a siezed release bearing. Cheap to fix.
Old 22-Jun-2005, 13:11   #4
m1keyp m1keyp is offline
Welcome
Where are you? you may find someone local on here to compare the proposed bike with.
Old 22-Jun-2005, 16:03   #5
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello
I was just going to say the same as m1keyp, I have a 748 with a 2001 engine if you are not to far away would be happy for you to compare, engine noise.
Would help the guys on here if you posted your location, and maybe a little more information, so somebody could help you out.
Good luck
regards
TopiToo
Old 23-Jun-2005, 02:58   #6
bagonails bagonails is offline
Sounds like a vented clutch cover, which would not make any difference to the noise. Clutch plates are £110 approx, slave cylinder is £65 I think, clutch basket a lot dearer.
Old 23-Jun-2005, 10:49   #7
I was just wondering if the cover has been fitted incorrectly. So when the clutch is operated, the pressure plate moves outward and hits the cover.
Old 23-Jun-2005, 10:58   #8
ziggi ziggi is offline
ziggi's Avatar
Welcome to DSC.
Ducati clutches are notorious for being quite loud, especially when they are older. You should notice a marked decrease in the clutch noise when the lever is pulled in (disengaging clutch). If it's the other way round there are a number of inexpensive and expensive reasons for this. One obvious reason could be, as already mentioned, an aftermarket clutch cover is incorrectly fitted. Get a standard one, put it on (5 mins work) and then try again.
Old 23-Jun-2005, 10:59   #9
ziggi's Avatar
or just take the cover off
Old 23-Jun-2005, 11:56   #10
Lily had a carbon cover which was too shallow and when as you suggested pulled the clutch lever in, the pressure plate hit the cover causing all sorts of grinding/graunching noises, simple fix was to put spacers on the mounting points to move the cover out by a few mil, which also aided dust removal and cooled it slightly also.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:15.
