Old 23-Jun-2005, 18:50   #1
hooley hooley is offline
hooley's Avatar
Mood: One day I'll be allowed out to play......
Tyre pressures for 916 at Snett this w/e??
Okay, novice question.......
Pirelli Dragon Corsas, 180 rear, part worn in centre. hoping to be very worn all round.
Snetterton weather - debateable, but looking like 17 celcius and a small amount of surface lubrication (rain).....
So what front and rear pressures do I run??
Road pressures are 32 front and 35 rear, and seem okay, but what do I know? - nuffink.
Jas
Old 23-Jun-2005, 19:11   #2
If we get a wet track stick with what you use on the road, if its dry and warm, just try dropping the rear pressure to 31psi.
Old 23-Jun-2005, 19:18   #3
yeti yeti is offline
yeti's Avatar
Dragon Corsa's I would try at 33 front 31 rear initially. If you can get them nice and hot, then you could go as low as 31/29 f/r, but this is very temperature dependant.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:51.
