Old 23-Jun-2005, 22:24   #1
Simonwalsh Simonwalsh is offline
Starting problem
Hi
Need some advice
Went to take the ST2 out this morning and just couldn't get her started!
The bike turns over fine so the battery seems fine. It just doesn't seem to fire up or even try to. I've never had this problem before and I'm not much of a spanner man but where should I start?
Old 23-Jun-2005, 22:43   #2
Kill switch?
Bike in neutral?
Side stand relay?
Old 23-Jun-2005, 22:57   #3
Hi Keefy - long time no see!
Yep - bike is in neutral.
Side stand - don't think the bike would turn over, would it?
Kill switch - wouldn't turn over, would it?
Old 24-Jun-2005, 00:32   #4
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
does the fuel pump prime? (the whirring when ignition is turn to on [not start])
Old 24-Jun-2005, 00:33   #5
Bikes: Ducati ST2
Mood: Fruity
also is there any fuel in it?
Old 24-Jun-2005, 15:26   #6
Howard Howard is offline
Mood: tyred and exhausted
Have you got the fast idle lever in the closed position and a closed throttle?
Mine floods unless you only open the throttle after it has caught and then use the fast idle to stop it stalling
Old 28-Jun-2005, 23:17   #7
Simon,have you got it sorted yet?
Give me a bell/U2U if you need a hand.
[Edited on 28-6-2005 by KeefyB]
Old 29-Jun-2005, 00:12   #8
Its interesting how bikes start! Mine starts without needing any fast idle or throttle. Just press the button and it starts and ticks over like a good un! The Monster does the same now we've got to the bottom of why it was running like a bag of spanners when we bought it!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:16.
