Old 23-Mar-2013, 14:31
Col996s's Avatar
Col996s Col996s is offline
Bikes: 996S
Rear indicator not working
Ironically I have just returned from an MOT and now my rear right indicator doesn't work. (Dash indicator light flashes fast). It worked when I went in and he passed it ok!
The strange thing is it lights when the alarm arms so I know it's not the bulb or the wiring to it.
Does anyone know where the flasher unit is on a 996 or is it controlled from the ECU?
Thank you.
Old 23-Mar-2013, 15:37
dunlop0_1's Avatar
Its down next to the battery. The big relay behind the cables next to the small yellow one.
Old 23-Mar-2013, 15:49
Col996s's Avatar
Bikes: 996S
Thanks.
Too cold to mess around in the garage now but i'll check it out.
Old 23-Mar-2013, 16:54
Jeez Colin - did you go out in the snow?!?
Old 23-Mar-2013, 17:30
Col996s's Avatar
Bikes: 996S
No it was actually yesterday. (you caught me out).
Old 23-Mar-2013, 18:58
Won't be the flasher as the other side works. Alarm will put its own power to indicator circuit, so it'll probably be a loose connector. Usual suspects are the ones under the ECU/seat catch area.
Old 23-Mar-2013, 20:20
Col996s's Avatar
Bikes: 996S
Thanks Nelly.
Old 24-Mar-2013, 18:33
Col996s's Avatar
Bikes: 996S
It was indeed just a bad connection in one of the bullet connectors under the seat. All ok now.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:35.
