Old 27-Jun-2005, 18:44   #1
Respro / Foggy mask jobbies.......what\'s the story?
Having broken the visor mechanism on my Arai, I used the Suomy lid for the race - which isn't as well ventilated as the Aria.
So in the heat of battle and being such a sweaty b'stard means that I steam the visor up on the Suomy all too easily... so what's the resolution?
I do have one of those Respro mask things but struggle to get this to sit correctly - so what do you others use - if at all?
Are you using masks that are designed specifically for the lids that you are using - or are you using standard items and I'm just weird? The Respro mask does have tabs that should be tucked in somewhere, but the Suomy has no space for these?
I remember in the old paintball days using washingup liquid on the inside of the googles to prevent steaming up, but this doesn't seem to work either.
I had to have the visor partially open for most of the race yesterday, so c'mon, tell me what's going on with this mask milarkey?
Tim
Old 27-Jun-2005, 18:46   #2
GsxrAge GsxrAge is offline
GsxrAge's Avatar
You could try some BOB HEATH visor anti fog spray!
It's all I have ever used.
Old 27-Jun-2005, 18:48   #3
dickieducati's Avatar
i use a foggy mask in my shoei and its great. fits well and does exactly what it says on the packet.
never needed one on my arai but i prefer the shoei paints scheme, its fits really well and is as good if not better in protection according to recent tests.
Old 27-Jun-2005, 19:01   #4
I have duct tape put over my nose just under my eyes and to the front of the helmet - No steaming up whatsoever Even have to do it with a mask in place too.
Old 27-Jun-2005, 19:03   #5
I had fogging issues before I got my respro mask and now I don't have any problems at all.
I think that it's not fitted it correctly?
Old 27-Jun-2005, 19:04   #6
domski's Avatar
You're not trying hard enough :P
I use a fog shield, but it still gets steamed up when I breathe heavily.
I've used masks, and tape, but the perspiration from your face will still fog the visor up.
Best to use a fog shield and maybe a mask to deflect your breath too?
Old 27-Jun-2005, 19:05   #7
Tonio600 Tonio600 is offline
Tonio600's Avatar
Mood: What a wonderful world.
I drilled my visor.
But it doesn't work. So now even my visor looks ridiculous. And I still can't see the track properly. I may try Lin's tip, it stays in my budget
Old 27-Jun-2005, 19:19   #8
You just have to make sure you stick it to your skin under your eyes then it don't steam up.
I never had a prob on the Arai but I do with the Shoei and I can't quite get the mask to fit right which is why it probably doesn't do the job.
The only thing I found was it were a tad painful pulling it off after the 30 min race
Old 27-Jun-2005, 19:24   #9
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Put a couple of spounges in your lid to soak up the sweat:P
Old 27-Jun-2005, 19:30   #10
Dibble
Rattler, one of these will help train you to breathe through your nose rather than your mouth thus reducing the risk of fogging ......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:42.
