Old 01-Jul-2005, 10:16   #1
Front sprocket removal?
As per my other thread about what chain is on my bike, sprocket has arrived and I had 30 minutes spare so thought I'd crack on with this little task.
Removed the sprocket cover to see a different setup to my 996 (plate with 2 5mm bolts holding sprocket in place) on the 999, and I'm guessing any Testastretta engine it's just one big (32mm) nut holding the sprocket in place.
Tried as hard as I could to get the thing to budge, but no joy, then it dawned on me maybe it's a reverse thread? does anyone know? anyone got any ideas how I can shift this nut etc
Old 01-Jul-2005, 10:19   #2
Pretty sure its not a reverse thread.
I reckon you've gotta do the usual lock the rear wheel jobbie. Either by applyig the rear brake or locking the wheel on a paddock stand.
Shouldn't be too tricky though.
Tim
Old 01-Jul-2005, 11:14   #3
bolds bolds is offline
its normal thread and air gun would be the easy option if available
Old 01-Jul-2005, 11:41   #4
Tim
Tried that Tim, Lily on the bike brakes on, in gear with usual bar etc from stand through rear wheel...
Must get bigger muscles
Old 01-Jul-2005, 11:46   #5
When in doubt - give it a clout!!!
Old 01-Jul-2005, 11:47   #6
khushy khushy is offline
khushy's Avatar
I did mine last weekend . . .
its a normal 32mm nut - that has been done up with an Airgun - needs to be "cracked" before it moves.
190nM is the setting - ferkin tight!
There is obviously a tab washer there as well.
A big bar and a second pair of hands helps - however you will be hard pushed to get the chain/sprocket off without cutting the chain first - I did a new chain and front sprocket (down to 14 teeth now at the front) last Saturday.
Makes a hell of a difference.
Khushy
Old 01-Jul-2005, 13:14   #7
keefer keefer is offline
keefer's Avatar
put the bike down on the floor so the wheel cant creap round and get a breaker bar on it man
[Edited on 1-7-2005 by keefer]
Old 01-Jul-2005, 13:37   #8
Rally Rally is offline
Rally's Avatar
Think that's worth repeating, JPM, since you didn't mention bending the tab washer back...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:19.
