Old 02-Jul-2005, 20:33   #1
keefer keefer is offline
keefer's Avatar
I see the light!!!
A warning light in my volvo 850 T5 has just come on and I don't have a clue what it is, just wandering if any of you peeps know..... No **** taking cause I drive a Volvo though
The light is situated under the handbrake light, it's a green triangle with what looks like a jack in it! Any ideas would be greatly received, cheers
Old 02-Jul-2005, 20:40   #2
Its the someone has stolen your jack warning light.
Old 02-Jul-2005, 21:01   #3
Is it the malfunctioning indicator lamp warning?
What year is your car?
Old 02-Jul-2005, 21:03   #4
http://www.volvocars.us/Volvocars.We...ACHEHINT=Guest
Might be worth a look
Old 02-Jul-2005, 21:04   #5
keefer's Avatar
It's a 95 model.
Old 02-Jul-2005, 21:08   #6
pg. 1:3 Indicator and warning lights
1 Turn signal, left
2 Turn signal , right
3 (Not in use)
4 Low washer fluid level
If the lamp glows continuously when the engine is running, there is only about 1/2 - 1 US qt. remaining in the washer fluid reservoir.
5 Low fuel level
When the lamp glows, only about 1.8 US gals. (8 liters) of fuel remain.
6 Rear fog light
7 High beams
8 (Not in use)
9 Bulb failure warning sensor
10 (Not in use)
11 (Not in use)
12 SRS
13 Generator not charging
14 Low engine oil pressure
15 Brake warning light
16 Parking brake applied
17 ABS-system
18 Ambient temperature warning light (certain models)
(See pp. 1:11 or 1:14 for more information)
19 Transmission mode "W", or gear positions 3 or L engaged (automatic transmissions)
20 Low coolant level
21 Traction Control System (option)
22 Malfunction indicator lamp
23 Service reminder indicator
lamp 22 is the one directly below the handrake warning lamp. The pictue of the dash wont copy.
Old 02-Jul-2005, 21:08   #7
http://apps.volvocars.us/ownersdocs/....html#controls
Old 02-Jul-2005, 21:13   #8
keefer's Avatar
Cheers Paul, just had a quick butchers at the site and does look to be an indicator lamp malfunction,although the diagram for number 22 looks different, as it's located above the parking light it must be that. Thanks again
Old 02-Jul-2005, 21:49   #9
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Keefer,
"I saw the Light," I thought you where gona tell us you'd finally bouught an 888.....
[Edited on 2-7-2005 by rob41b]
Old 02-Jul-2005, 23:32   #10
keefer's Avatar
Just realised the website posted up by rockhopper was an American site so still am at a loss as to what this poxy light is........ there must be some other volvo owners in the DSC,c'mon own up.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:28.
