Old 05-Jul-2005, 20:41   #1
ttstu ttstu is offline
Mood: On the mend!
Indicator Problem
Eventually got a bulb put it on and guess what? Still doesn't work! Therefore the front indicator isn't working because of the bulb. (Make a good detective me)
Any idea what I should check next?
All other ones work therefore it can't be a fuse.
Where should I start checking?
Ta
Old 05-Jul-2005, 21:15   #2
Do either direction not work, or is it just one direction?
If it is just one front direction, i would check the wire connections between the indicator/mirror and where they join in the nose fairing.
Old 05-Jul-2005, 22:02   #3
guest1 guest1 is offline
Ta
swap bulb with indicator that is working just to make sure.
Old 05-Jul-2005, 22:23   #4
Mood: On the mend!
After swapping bulbs abd the plastic plugs over as a process of elimination I discovered the rubber cap on the underside of the fairing as refered to by andyb and guess what??? After waiting 8 weeks for a bulb it was a dodgy connection!
Oh well at least it's sorted.
Thanks for the advice guys.
Old 05-Jul-2005, 22:42   #5
Thatll be £90 please for 1 hours labour! :P
