Old 06-Jul-2005, 14:06   #1
Henners Henners is offline
Trouble at mill
Following a full service on the 996R I was looking forward to getting some miles under the new Corsas and went off on a jaunt with Webby to Worthing on one of the hottest days of the summer a couple of weeks ago. All went well until we got to the town and in the stop-start run through to the seafront the engine soon got up to 115C with both fans going furiously – the enclosed fairing always run the engines hot in traffic. Coming back out of the town the engine started to lose power – almost as if it was cutting out on one cylinder and it was a struggle to keep her going at traffic lights. Out onto the open road and although the temperature dropped the problem persisted – you would get up 7000rpm and then the engine would slowly lose power until the revs dropped back down to 4-5000 – open the throttle made it worse, then all of a sudden full power would cut in and wheeeeeh ….
After a while the problem disappeared and didn’t come back until the engine got hot again some days later. Over the last week the problem has been there almost constantly so I spoke to Snells who managed to free up Carl for a couple of hours to look at it. Prior to going I armed myself with a new ECU just in case courtesy of the kind and generous Andy Banes (andyb) who sent me three to try – thanks Andy
Well, the problem is now solved. Any idea what it was? A prize for nearest the right answer .....
Old 06-Jul-2005, 14:11   #2
A failed sensor?
Old 06-Jul-2005, 14:15   #3
Good try TP - not correct :P
Old 06-Jul-2005, 14:16   #4
beancounter beancounter is offline
beancounter's Avatar
Mood: Black and grey (and a bit of red)
Blocked fuel breather ?
Old 06-Jul-2005, 14:17   #5
Nope - not even close
Old 06-Jul-2005, 14:19   #6
Loose connection?
Old 06-Jul-2005, 14:21   #7
No - nothing like that
All the clues are in the intro .....
[Edited on 6-7-2005 by Henners]
Old 06-Jul-2005, 14:28   #8
keefer keefer is offline
keefer's Avatar
spark plug
Old 06-Jul-2005, 14:31   #9
The ECU?
Old 06-Jul-2005, 14:33   #10
Dibble
the rider ????
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:42.
