Old 08-Jul-2005, 14:32   #1
KP KP is offline
Mood: Replacing 999...
999 Febur Carbon Seat Unit help
I have a single carbon seat unit for my 999 biposto. Its from Febur, Italy.
If anyone else has one, how on earth do you line up & put the side bolts back in that fasten the side of seat to the frame?
Old 08-Jul-2005, 14:37   #2
Dibble
hammer and superglue .....
Old 08-Jul-2005, 14:38   #3
Dibble
oh, Rattler will be along in a bit to tell you which sort of hammer .. he has one for every occasion ...
Old 08-Jul-2005, 15:58   #4
Got any photos?
It's not an RS copy is it? as being supplied with lots of track day kits, if so you've got no chance sorry
Old 08-Jul-2005, 20:27   #5
How far out are the holes?If its a few m.m,it may just be a manufacturing fault.Cured with a drill!!!
If they are way out,check you have the tank correctly fitted.I assume the seat unit fits the same way as standard?
Old 09-Jul-2005, 14:32   #6
Brogins Brogins is offline
Brogins's Avatar
Mood: PENSO POSITIVO....SEMPRE!!
Do like I did with mine - no febur anyway - you don't put the side bolt back....
Old 12-Jul-2005, 11:44   #7
KP KP is offline
Thanks for the suggestions - not keen on hammer and superglue, upsets the cosmetics (the bikes not mine!).
Its not that the holes dont line up just cant get the bolt in. If its safe to not put them back that's simple - I was just concerned it may not be structurely sound. May have to consider drilling an access hole then popping a little rubber thingy over the hole once I slotted the bolt in. Then again that seems like too much admin. Think I will wing it.
BTW good luck on the jod front Dibble - what do you/ did you do?
kp
Old 12-Jul-2005, 15:19   #8
tricky tricky is offline
Mood: Need spares
I had a similar problem with my seat unit, I just drilled the holes in it so you can poke the allan key through to the bolt.
Old 13-Jul-2005, 11:03   #9
KP KP is offline
Thanks Tricky - think I will do the same. I guess the bolts are there for a reason so I should not just leave 'em out. Is that a carbon tank?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:11.
