Old 13-Apr-2013, 14:52   #1
batesy2 batesy2 is offline
Bikes: ducati 620ss racer,aprilia rsvr mille,husqavarna 125 crosser
Mood: easy going,love to laugh,fairly competetive
little ends
Hi Guys,Doris developed a rattle at cadwell which appears to be front cyl little end,I got a new bush from ducati 066047290 which im assured is correct,problem is the pin wont go through it,Is it normal to have to hone this bush after fitting,I have not fitted it to the rod yet but pin wont go in,
Any help/advise appreciated guys.
Old 13-Apr-2013, 15:37   #2
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
SeeleyG50's Avatar
Mood: The Older I get the Faster I Was!
Measure it up to check that things are close. Press it into the rod & get it honed to size. Bit like you'd do with a valve guide really.
Old 13-Apr-2013, 19:26   #3
Thanks,I was hoping to do it in situ, sounds like thats not feasable now DAMN !!!!!
Old 13-Apr-2013, 20:32   #4
I've not done a small end other than a two stroke but back in the 80s I use to use a Reamer for the valve guides. That way you could probably do it in Situ
Old 13-Apr-2013, 22:56   #5
I know its late & I'm semi ****ed but two strokes don' t have valve guides.
Old 13-Apr-2013, 23:13   #6
Your just taking the P again, just because I used my phone for the previous post
didn't quite come out as intended
On 2-strokes I just had to change the needle roller bearings in the small end
and on 4-stroke I would use a reamer to get the correct internal bore on the valve guides
Something like this
http://www.ebay.co.uk/itm/Brand-New-...em2328d9 9647
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:04.
