Old 15-Jul-2005, 01:35   #1
BEANO BEANO is offline
900SSIE wont start poss pump prob
HELP PLEASE
my bike wont start turn ignition no whirrring from pump , fuse ok , stuck meter across pump connections and when ignition turned on 12v across wires ok , if pump connected direct to battery it turns no probs but wont turn when connected back on to pump terminals although 12v is present . Is pump knackered
Old 15-Jul-2005, 01:47   #2
is there 12V on the wires when the pump is connected or is it with it disconnected, if its the later I would be interested to know if the voltage is getting pulled down when connected to the pump.
Could be a dirty filter causing the pump to try and pull to much current and causing a voltage drop.
Old 15-Jul-2005, 01:54   #3
....12V on the wires when the pump disconnected ...
good thinking batman i will try with connected tommorrow ...
Old 15-Jul-2005, 19:07   #4
new pump still pump doesnt turn filter not connected
Old 16-Jul-2005, 20:04   #5
All sorted it was the relay altough working there was a big resistance through it... also this relay is prone to failing alot , when i went to get new one , they said they kept plenty in stock as they were the most unreliable relay in the world..
[Edited on 16-7-2005 by BEANO]
Old 17-Jul-2005, 21:40   #6
That'll be the same relay they fit on Monsters then!
We keep a spare one under the seat on the missus bike.
Old 18-Jul-2005, 00:31   #7
YES i brought 2,,, 1 as a spare under the seat ,..
GUZZI's also have the same prob see- CLICK HERE
SEE HERE FOR A BETTER REPLACEMENT
Old 19-Jul-2005, 07:15   #8
Some good info there,...cheers.
I think its also the heat from the engine that affects the relays.On the Monsters they sit next to the battery right above the engine.My wifes bike would often cut out when the bike was hot,but never when it was cold.
Old 19-Jul-2005, 10:20   #9
scully scully is offline
scully's Avatar
Mood: I need to get out and ride more!
Aargh this may answer a problem Ive been having on my 1000SS! When she gets very hot the revs take on the habit of dying off before the engine finally stalls. I was thinking of tweaking the idle speed to stop it happening but it doesnt do it when its cold/warm so Im a bit loathed to do that.
A case of putting up with it and adjusting the cold start lever to stop it stalling I suppose...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:42.
