Old 17-Jul-2005, 17:45   #1
Gav748sp Gav748sp is offline
Mood: Updating The Formula!
Anyone else bought/fitted slipper from Nick via Ebay?
Specifically the 4 post one.
Has anybody had any problems fitting these? I have fitted mine to the bike usuing the correct nut and spacer as per Nick`s instructions, fitted the clutch pack, pressure plate. springs and caps....the problem arises when after tightening up the spring cap retainin bolts it locks the clutch solid ie the springs are too compressed!
Open to suggestions on what i have overlooked/just can`t see for looking at it... and yes, before you suggest it all parts are correct and stack height is also spot on.
Thanks in advance.
Gav
Old 17-Jul-2005, 18:23   #2
The spring caps are a diffrent depth. You need shorter caps
Old 17-Jul-2005, 19:15   #3
Sorry you have it the wrong way round, the spring caps are if anything too short.
Old 17-Jul-2005, 19:20   #4
What do i know..................
Old 17-Jul-2005, 22:06   #5
Andy, have looked at the clutch again and when tightened up, half the bolt head sticks out the top of the spring caps, thats how shallow these ones are.... any shallower and it`d basically be just a flat washer!
Thnx anyway.
Old 17-Jul-2005, 23:13   #6
On my 6 ti post stm the bolt heads are flush with the cap tops.
Old 18-Jul-2005, 00:36   #7
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
Did you change the top hat spacer?
[Edited on 17-7-2005 by Jon]
Old 19-Jul-2005, 00:28   #8
yeti yeti is offline
yeti's Avatar
I don't need a spacer for MY Top Hat, my head is quite big enough thank you!
Apologies for the temporary hijack of this thread but couldn't resist that one!
Old 19-Jul-2005, 00:35   #9
Can't really speak for the seller, but his latest Haga bodywork isn't original as listed on Ebay, no vents in nosecone or side fins, and the paintjob is out by a fair bit
Old 19-Jul-2005, 01:20   #10
I have bought one of his 6 post slippers and all we (read Nelly) had to do was find another nut to fit the bugger on. That's it.
Great clutch. I didn't want a 4 post one though because it didn't have the ball bearings and therefore would need more maintenance.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:32.
