Old 17-Jul-2005, 19:19   #1
Flatspot Flatspot is offline
another post crash question
Just noticed that I have more right loch than left, so the headstock has taken a bit of a batter when the bars hit the deck.
Apart from a basic visual check to make sure everything looks to be lining up and a test run, is there anything else I can do to check my front end is ok? She still rides fine and corners well.
I noticed my tie wrap on my fork was pushed to within about 10mm of the botton of the base. Cant beleive how badly I went for the brake
Mike
Old 17-Jul-2005, 20:26   #2
Twinfan Twinfan is offline
Twinfan's Avatar
Sounds like you've damaged a lock stop. I know, it happened on my bike...
Old 17-Jul-2005, 20:52   #3
Mood: me in a mood? NEVER!
yup sounds like that to me so stick your head under the front of the fairing and youll see the lock stop there.
Old 17-Jul-2005, 23:49   #4
Murray Mint's Avatar
The lockstop is the ****iest peice of metal you have ever seen, the way i dealt with this problen when it happened to me was to take a hammer to the offending part. Dont make a habit of bending this part as after a while it may snap off.
Murray Mint
Old 18-Jul-2005, 00:07   #5
Sounds about right, bottom of the head tube you'll see a flimsy tab of metal, probably bent, also you should have some screws/bolts on your bottom yoke you can adjust also
Old 18-Jul-2005, 00:32   #6
Rally Rally is offline
Rally's Avatar
If it is bent then remove the air tubes so you can get better access with a bar (like a socket extension bar). Rest one end against the bent stop and tap the other with a hammer. It will have to be a heavy hammer but aim to tap it lots of times to straighten it rather than a couple of heavy slugs.
Guess who's had to do this one too...
Old 18-Jul-2005, 00:38   #7
749er 749er is offline
749er's Avatar
Twinfan, have you had any news about your brembos yet?
[Edited on 17-7-2005 by 749er]
Old 18-Jul-2005, 11:43   #8
Twinfan's Avatar
Yep...
