Old 17-Apr-2013, 02:54   #1
funkatronic funkatronic is offline
WANTED: Monster Headlight U Bracket
Hi all
looking for a Monster Headlight U bracket
ideally type with mountings lugs for air pressure sensor found on later model old shape monsters 2002-2007 eg 620/800/1000/s2r/s4r but will consider others
any of you have one kicking about?
Old 22-Apr-2013, 18:25   #2
Found one in the workshop, just the Main bracket found so far, do you also need the two side plates that the headlight bowl bolts to and do you need the inner steel bracket that the Air Temp/Pressure sensor fits to, if so I will see if I have those bits about also
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:59.
