Old 19-Jul-2005, 21:26   #1
748 Fitment size
Due to a cock up on tyres I have been offered a set of K2 Racetechs as used by the Superstock Cup boys. the size is 120/70 front & 190/50 rear, the rear is said to be more like a 185 than a 190 & most of the 600 supersport boys are now using them, so they will easly fit the 5.50 rear rim of my 748.
Question is, has any one on a 748 used this size of tyres? & how did they get on with them???
Chris.
[Edited on 19-7-2005 by chris.p]
Old 19-Jul-2005, 23:13   #2
keefer keefer is offline
keefer's Avatar
no I use a 190/55
but then I have a six inch rim.
give it a go and see how it feels
Old 26-Jul-2005, 09:11   #3
Yep it was a 190/55, not a 190/50. Had no problems apart from the fact that I had to muscle the bike into a lot of the tighter corners, so not the best fitment for a 748, worst places being the Chicane, bottem of the mountain(the left to right change of direction) & Hall bends.
Chris.
Old 26-Jul-2005, 10:25   #4
berto berto is offline
190's designed to be used on 6" rims not the 5.5's of a 748 whoever recommended that tyre is an ******** cos the 748 doesn't need a bigger tyre with the power it puts out!!
Old 16-Sep-2005, 23:27   #5
rob jones rob jones is offline
Dude keep with the standard fitment of a 120 70 17 front 180 55 17 rear or you will completely mess the handling up . a 190 on a 5.5 rim gives a smaller contact patch than a 180 plus it will make it slower to turn in. try the 190 if you like but it will make you loose confidence in your handling.
Old 17-Sep-2005, 09:11   #6
butch890 butch890 is offline
Mood: Enjoying Togdom !
i thought stanard front fitment on the 748 was 120/60
Butch
Old 17-Sep-2005, 10:59   #7
keefer's Avatar
it is but 120/70 is better
Old 17-Sep-2005, 10:59   #8
Brent Brent is offline
Brent's Avatar
120/60 is the standard fitment, but many people find that the 120/70 (including me) works better for them.
Old 06-Oct-2005, 22:38   #9
Mike Davis Mike Davis is offline
Mood: Shiney
a 190 on a 5.5 rim will give greater contact patch at maximum lean, thats why the supersport guys use them. It makes an egg shape because its squeezed on to a smaller rim, less stability in a straight line but a larger contact patch at full lean. useless on the road however as it helps the bike drop on its side quicker making it feel unstable at lesser angles of lean.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:38.
