Old 20-Jul-2005, 17:28   #1
gimpboy450 gimpboy450 is offline
gimpboy450's Avatar
Mood: crank it and bank it
Termi fitting
Just bought a new 50mm Termi System with Air Filter and CPU thingy. I can probably fit everything myself but was just wandering why it needs any setting up at a specialist? I thought its a bolt on goodie and no need to eff around??
Old 20-Jul-2005, 17:49   #2
Twinfan Twinfan is offline
Twinfan's Avatar
You need to get the CO2 trim pots set up properly. That's why you'll need to go to the dealer.
I think if you bolt on the pipework, you could then get the ECU, filters and CO2 done by the dealer for a low cost? They need to remove the tank (I think) to do the CO2, so they might as well fit the ECU and filters.
Old 20-Jul-2005, 18:14   #3
gimpboy450's Avatar
Cheers buddy, if you fit everything without the CO2 setup will it work okay?
Old 20-Jul-2005, 22:54   #4
swannymere's Avatar
Mood: High as a kite!
It will work,but you won't get any benefit from having fitted the system.It might run lean/rich or just rough.I fitted mine just before my service so that it could be sorted out then.Give a dealer/specialist a ring and ask how much to fit or just setup after you've fitted it.
